lack of power e55 w210?? HELP
Old Jul 1, 2007 | 12:42 PM
palmer3914's Avatar
2002 e55 w211 ....
Exclamation lack of power e55 w210?? HELP
hi guys new to the fourum ...... and new to mercedes ownership .....
just bought a 1999 E55 AMG W210 .... and im in the uk.
now just had the air con re-gassed and climate re-set etc etc..... at same time my mech told me the throttle hadn't been calabrated???????? so he did that for me as well... this could be due to bat going flat......
BUT ANYWAY........
the car low down and midrange seems to pick up quite well but top end really seems to struggle............ i have had it plugged in via multi plug under bonnet and at time of this it had 2 ACTUAL faults which said FUEL TRIM both of them that is...............
can anybody point me in right direction .... no other faults listed.... idles fine, drives fine, etc etc etc....
thanks
Old Jul 1, 2007 | 01:06 PM
E55 Estate Fan's Avatar
E55 AMG Estate W210 1998
Hi Palmer
Welcome aboard!
Terrific choice of car if I may say
I'm wondering what mileage it's done & whether the car's MAFs have ever been cleaned or better still replaced?
Are you able to join us for a visit to Mercedes World in Brooklands this week, probably Friday? See the thread for more info. It would be great to meet a few other AMG owners.
Regards
Chris
Old Jul 1, 2007 | 01:19 PM
palmer3914's Avatar
2002 e55 w211 ....
hi there, from what i can see its prob never been cleaned nor replaced..... its covered 83k miles ......
also 1 thing i would like to ask ..... when you turn ignition on so all lights come on dash should engine check light come on then go off, or not light at all and only come on when there is a problem ...?
as i cant see mine on ignition ... and was wondering if someone has played the pull the bulb out trick due to this possible air flow meter problem???
cheers
Old Jul 1, 2007 | 01:38 PM
Waynec1980's Avatar
2001 ML55 AMG, 2011 VW Passat, 2001 S500L, 2002 S500L
Well I may come along to brooklands in my E55 or C43. I have a diagnostic scanner that I could bring and plug it in if you wish. It is an amazing tool.
Let me know.
Old Jul 1, 2007 | 01:41 PM
palmer3914's Avatar
2002 e55 w211 ....
i could do with 1 of those scanners ... just to let me know whats what? where's best place to get 1 from..? as all i can find is obdII ones and i dont think the w210 has a port just that round 1 under bonnet?
cheers
Old Jul 1, 2007 | 02:12 PM
cheers
I'd say the MAFs are due for a clean or replacement then.
Regarding the lights, just been outside to mine & when you turn the key so that all the lights come on, I do not see an engine warning light (is there such symbol?). All I could see were 3 orange symbols on l/h/s for ABS, footbrake & BAS/ESP, in the middle of the display was an exclamation mark in a triangle (ETS/ASR/ESP check), the LIM (cruise control) symbol & finally the SRS symbol.
Chris
Old Jul 1, 2007 | 02:20 PM
palmer3914's Avatar
2002 e55 w211 ....
yeah quite possibly ... just bought one off german ebay (MAF) for £70 new so well worth it even if mines ok...... i will have a look at it during the week and clean it if needs be... i guess a simple dash of WD40 or similar will do the trick as thats what i have done on past cars......
and thanks for looking for me outside, that makes me feel a little better a s they are the bulbs that come on mine as well...... i just thought if there was a "fuel trim error" the engine light should have come on... thats all..
but thanks for help.. no doubt il need more soon
Old Jul 2, 2007 | 04:36 AM
palmer3914's Avatar
2002 e55 w211 ....
another thing ....... last night i went to a empty bit of road to attemp a rough 0-60mph as convinced it not running right...... 0-60mph came up in 9 seconds!!!!!!!
now thats def not the sub 6 seconds quoted!!!!!!!!!!! so def down on power i would say .......
it feels like it pulls upto abou 3-4000 rpm BUT after this it struggles and climbs very slowly
Old Jul 2, 2007 | 06:37 AM
Let me know.
Hope you can make it Wayne. Friday the 6th of July looks good for Mr Nu & me
Chris
Old Jul 2, 2007 | 06:50 AM
mmm....additional suggestion..when was it last serviced, was it a minor 'A' or major 'B' service & where?
Just bought mine & it had it's main B service, just 200 miles beforehand & had its MAFs replaced too. Mileage 66000.
The car goes like stink. The rear tyres need replacing asap, however, when I have floored it, on one of those rare dry days, the semi slick tyres hooked up really well, the traction control was not intrusive & it scorched off the line, to the delight of my 7 year old boy safely strapped down in the boot
Acceleration almost identical to my old e39 M5. With new rubber due to arrive & be fitted all round any day now, I think the grip, particularly in the wet weather we've been experiencing for the last month, will be significantly improved.
Chris
Old Jul 2, 2007 | 10:22 AM
palmer3914's Avatar
2002 e55 w211 ....
due a service in 5400 miles so it tells me.......... no reciepts for a maf sensor so assume its the original 1, cars done 83k... bought new one so waiting for that to turn up then il fit it and get the fuel trim codes re-set....
Old Jul 2, 2007 | 11:43 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
sounds like a MAF problem, and I hope that it is since it's pretty easy to fix... could be anything 02sensors you have 4 of them better not start, I hope problem will be solved changing the MAF, oslo you should be able to see check engin elight when you turn your key it's on the right hand side, good luck and ejnoy your ride !!!
Old Jul 3, 2007 | 09:41 AM
palmer3914's Avatar
2002 e55 w211 ....
hmmm i have no light on right hand side, and the other guy checked his and he didn't have 1....... ...... hhmmmm does this mean someone has played the taking the bulb out game????? if so how easy is it to remove Cluster to have a look??
cheers
Old Jul 3, 2007 | 10:21 AM
Hi SaMaS, I've just read through the section in the manual for the car's instrument cluster & there is no mention of a specific engine warning light. According to the manual, on the r/h/s there is only the SRS symbol; unless yours is actually a diesel & you've got the diesel engine preglow symbol
Perhaps I can't see the wood for the trees
Chris
Old Jul 3, 2007 | 11:55 AM
palmer3914's Avatar
2002 e55 w211 ....
i too looked through manual, now there is mention of a engine check light ...... but no pic of it on cluster when the manual describes whats what........????
now different car i know, but my omega track car, on ignition engine light comes on and as soon as you start it goes out..... which is what made me think...
but on other hand my old e39 BMW had a engine check light but didn't come on with ignition and only when problems arose which was once....... ???
my reason for asking mainly was this fuel trim issue of 2 codes flashing up on diagnosis showing actual faults.... now wondered if in fact engine light should of been on with this fault???
was only by chance i asked a friend to check if everything was ok with car, as idled fine, ran bellow 3k lovely............. only top end suffered......
ON A DIFFERENT NOTE
last night decided to take air box out as didn't realise how easy it is..... to see the air filters were so black and full of rubbish inc almost a whole bird!!!!!
new ones arrive tomorrow and il replace them, also noticed a small hose had been disconnected on right hand side of engine bay, only small...... so plugged that back together and she seems to be acting much better touch wood....... so basically my main aim is to get rid of any faults flashing up..... which was only the trim errors on both banks........ I HOPE!!!
but i would like to thank everyone on here for your imput been a great help...........
Old Jul 3, 2007 | 12:09 PM
Who last serviced your car? Was it a MB dealership or independent please?
Old Jul 3, 2007 | 12:34 PM
palmer3914's Avatar
2002 e55 w211 ....
going by service history some indipendent person...... so whoever it was not really up to scratch i think!!!
