Removing chewing gum from floormat?
Chris
Hope you're well.
As far as I know there is an actual product on the market that is designed to be sprayed on which allows you to literally pick off the offending substance. Cant think of the name off the top of my head, but it is based on some kind of Co2 delivered nitrogeon substance.
Although Xabo's ice cube solution is definitely a cheaper alternative to begin with!
Nath
Hope you're well.
Nath
Hi Nath
Thanks, at least one way or another that revolting stuff is coming off.
Chris
Thanks for all the suggestions, in the end, I got it off by using one of those plastic suede shoe brushes with the really stiff bristles, a bowl of soapy water & a bit of elbow grease. The chewing gum came away in tiny pieces, stuck to the bristles on the brush
Chris
