01-02 W210 E55 headlight removal??
Old Jul 18, 2007 | 05:52 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
anyone know how to remove the headlight. Do you have to remove the bumper??
thanks
Old Jul 19, 2007 | 09:08 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
00-02 yes you need to remove bumper...
Old Jul 19, 2007 | 10:22 AM
Any idea how to remove bumper?
has anyone reomved the front bumper and remember how to?
Old Jul 19, 2007 | 12:23 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Yes and it's a PITA!!! Briefly, you must first remove the screws on the back side of the fenders in the wheel wells. Once your remove those you'll notice a bracket right above them, slide the bracket inward and remove it. Next, pop out the side marker lights and remove them, push the bulbs inside. Then, go underneath the front and unplug the foglights. After that, open the hood and remove the screws attaching the bumper to the headlights. Look in the middle in the front of the radiator, you will see a black plastic radiator guard, remove the tabs at the top and pull it up and out. This will give you access to the 2 screws on the inside behind the front of the bumper. Good luck on removing these screws but once they're out, the bumper will slide right off when you pull forward. Once off, you will see the screws to remove the headlight in plain sight. To re-attach, reverse everything above starting from the last thing I mentioned. What might be helpfull to prevent scratching upon re-installing would be to stick some blue painters tape along the bottom edges of the front part of the frenders where the corners of the back of the bumper attach. This will keep the corners of the bumper from scratching your fenders when you're trying to align it on installation. Good luck!
Old Jul 19, 2007 | 01:21 PM
thank a million!
all these trouble just to remove the head light. Wish they make it easy like the older model.
Old Jul 19, 2007 | 01:47 PM
My old W210 was so easy...
Old Jul 20, 2007 | 01:01 PM
eXpLiCitW210's Avatar
I own a 1999 W210 Mercedes.
Cool
Good information , yea older model W210s you only remove the small cover under the headlight to access the removal screws. Good Luck.
-Leo
Old Jul 20, 2007 | 01:49 PM
Check these video out! W210 how to
How to remove headlight
http://www.youtube.com/watch?v=atv1zg2G85g
How to remove side Mirror
http://www.youtube.com/watch?v=Qn0bg...elated&search=
How to remove center console
http://www.youtube.com/watch?v=qzpkS...elated&search=
How to remove side door moulding
http://www.youtube.com/watch?v=cMCsw...elated&search=
Old Jul 20, 2007 | 01:53 PM
can someone translate what he doing with the climate control
it in German
http://www.youtube.com/watch?v=XzgIkFjRceg
Old Jul 20, 2007 | 02:34 PM
Thanks Peter but this is for the 96-99 front bumper and is completely different then yours...
