Anyone know diameter of W210 E55 TB?
Old Dec 11, 2007 | 05:09 AM
Ted Baldwin's Avatar
300ce
.......the W211 E55 stock TB is 70mm. What is the diameter of ours?
Ted
Old Dec 11, 2007 | 06:04 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Ted
I think 65 or 64 mm! Rich (Mbenzman) could tell you for sure!
Old Dec 11, 2007 | 06:42 AM
300ce
...........thanks. I have a TB from my G55 that I removed when I upgraded to the Kleeman 80mm TB. I was about to sell it when it occured to me that I may be able to wap it into my s/ced W210 e55. I wonder if it can be a direct swap. I'll ask Rich.
Ted
Old Dec 11, 2007 | 02:46 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Dumb ? What's a TB?
Old Dec 11, 2007 | 02:49 PM
JamE55's Avatar
Out Of Control!
Originally Posted by E55 KEV
Dumb ? What's a TB?
C'mon Kev! You're brighter than this! Throttle Body.
Ted,
I think our stockies are 68mm.
Old Dec 11, 2007 | 05:01 PM
300ce
Ted,
........You are right. I just confirmed that our stock ones are 64mm and the stock AMGV8K ones are 74mm. I am not exactly sure how they are measured. My ruler tells me that the inner diameter of the AMGV8K TB I have on my desk is 70mm, but I must be measuring it differently.
..........JamE55, in an old thread you mentioned that you were doing a TB upgrade. Is that completed? I am looking for a completed kit. I also don't mind having my car used for R&D if the labor can be free. I already have the part.
Ted
Old Dec 11, 2007 | 05:11 PM
E55 KEV's Avatar
Veteran: Air Force
Ted,
I was testing you JAM!
Old Dec 12, 2007 | 01:26 AM
jeff.bisonett's Avatar
2001 E55K
Ted,
What is the expected hp gain?
Old Dec 12, 2007 | 05:02 AM
300ce
Originally Posted by jeff.bisonett
Ted,
..............best answer is that I do not know. The W211 E55 guys are getting 15 or so RWHP from the TB upgrade, but their cars are s/ced. I am not very knowledgeable about this and I am looking for someone who has some first hand info. I can only imagine how much it will cost if it was done experimentally at an hourly labor rate, especially if custom fabrication is required. I thought JAME55 has had this done, but I'm not certain. Maybe He will chime in.
Ted
Old Dec 12, 2007 | 09:52 AM
JamE55's Avatar
Out Of Control!
Ted,
Check PM.
Old Dec 12, 2007 | 11:26 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Ted,
Check PM.
Oh so now there's secrets huh???!!!
Old Dec 13, 2007 | 01:02 AM
2001 E55K
Maybe James should head to the dyno and post up his sheets....
I am running Kleemann s/c... if the price is right, I'd do it for 15 whp... as long as driveability is not sacrificed. Keep us posted, Ted.
Old Dec 13, 2007 | 07:18 AM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Ok..... if the TB is enlarged on our NA cars, should that make any difference UNLESS the amount of air is increased? Meaning even if putting a larger TB on our cars with the stock air box, that shouldnt yield anything , right? I bought a new OEM TB recently and I was going to experiment with porting/polishing it given that I still have a stock air box...any thoughts?
Old Dec 13, 2007 | 05:58 PM
NitrogenBalance's Avatar
none
There was an old member "grumpy666" who knew some pretty interesting stuff. I recall he once wrote about how to tell if a TB was properly matched to a motor. I don't recall if it was applied to N/A testing F/I or both. However, if I remember, it was explained that intake vacuum should be tested at the TB during acceleration to WOT. Our TB's actually have a nipple which would allow this.
From what I recall a properly sized TB should show only the slightest bit of vacuum when the motor is running at WOT, showing no restriction. Where a smaller TB would introduce restriction as sizes got smaller which would be seen as intake vacuum measured at the TB port.
I could be way off with this, but I remember reading it and it makes sense in my head.
I've got an extra TB from an ML55 if anyone wants to play with it....
Old Dec 15, 2007 | 02:04 PM
ProjectC55's Avatar
Ted
Did'nt I tell u this in the 2nd post! And you give JamE55 the credit!
Old Jan 9, 2008 | 08:40 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
All M113 500 motors and N/A AMG 55's have 74mm TB's Part # is 113 141 01 25, There is NO such a thing as 64mm .
AMG 55K 74mm TB- 113 141 06 25
AMG 55K 80mm TB- 113 141 05 25
Old Jan 10, 2008 | 07:01 AM
ProjectC55's Avatar
I have to agree.
I have Albert's E55k throttle body here that I have to send back and it's the same exact diameter of the stck throttle body I have on my car now (N/A113)!
Old Jan 10, 2008 | 09:48 AM
none
Anyone want the ML55 TB I have to mess with it. I'll let it go cheap as I keep moving it from drawer to drawer in the garage. I think a few people here had their TB's ported a while ago.
Old Jan 11, 2008 | 04:40 AM
E55 PWR's Avatar
e55
Throttle body is usually one of the last modification you do b/c it requires a decent amount of airflow to net any legitimate high end gains. The gains are always in the last 1000 rpm of the powerband, they prevent the power from dying off as quickly after peak HP is reached, usually the power will just level out instead of falling off, or might even keep going and peak at higher rpm (depends a lot on intake manifold and type of cams the car has).
74-80mm will probably net 5-8 wheel HP on a lightly modded E55 AMG. SC is totally different animal so you can't compare that to the NA 5.5Ls. You probably won't truly be able to unlock its potential until you get high performance headers, X-pipe, high flow filters and some other stuff as well.
Keep in mind though, usually throttle bodies require software upgrade b/c the amount of air entering the engine is significantly different and it can cause you to run a lean condition. The ECU might be able to adapt... it might not
it will of course sharpen up throttle response as well but b/c the cars are autos I don't know how much of that will really be able to be felt
I'd save this mod for last, but if you have aftermarket SC on your car or alot of mods, this one is for you.
Old Jan 20, 2008 | 03:16 AM
john niki's Avatar
1999 e320
any idea what the weight distribution front to rear is on a 1999 e320 and what it is on the 1999 e55? curb weights would be useful too, Thank you
gotogreece@gmail.com
Old Jan 22, 2008 | 01:54 PM
E55 KEV's Avatar
Veteran: Air Force
for 2002 E55
CURB WEIGHT:
3768 pounds
