KLEEMANN SUPERCHARGER PICS&PROJECT in my W210 E55 AMG
Old 02-08-2009, 09:10 AM
ABALONE's Avatar
2001: Supercharged E55 AMG
OK friends
Received my Kleemann S/C on Friday, and the thing looks absolutely great
Going to install it in middle of March or beginning of April when the snow has let go of our country
After doing some research and asking a few guys here (Thanks Jeff.B and BlackBenz) I'm going to have a company make a bigger "heat exchanger" and skip the small black one that came in the Kleemann package. A firend of mine has done this and he lowered the intake temperature with over 20 degrees celsius So I think that will be a nice mod
When all is mounted the car will be running:
Kleemann Eaton S/C
Kleemann Headers
Full Exhaust with 2 race cats
99 Octane fuel
Looking for 500 HP at the crank and I'm happy
Some pics for you. I'll keep you updated
Old 02-08-2009, 10:57 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Sweeet!!
Does your come with the E430 intake box? I think the airbox is restricted and not a good design for the SC. I place a temp sensor in the airbox and while sitting in traffic and drive threw the temp can get up to 160 degree it cool down once you start moving above 30mph.
Good Luck and hope you won't run into any installing problem.
Old 02-08-2009, 11:08 AM
ABALONE's Avatar
Originally Posted by Peter_02AMG
Sweeet!!
Thanks!!
Yes, but the problem you have with the heating is due to the small black heat exchanger that comes with this kit, and not because of the single air box. A bigger custom made heat exchanger will solve this problem because it will cool the water in a much better way then the small black Kleemann stock heat exchanger.
At higher speeds a twin-airbox will probably be a better solution serving the engine with cooler air. But again, it probably won't solve the heating issue of the charger when driving in slow traffic.
Old 02-08-2009, 11:23 AM
45acp's Avatar
BMW
wow you did it man congrats! its going to be an animal when you get everything installed.
definitely keep us updated!
Old 02-08-2009, 11:56 AM
Originally Posted by ABALONE
Thanks!!
It doesn't matter how big your heat exchanger is, it is useless if no air getting through it. My point is all the hot air from the engine is sucked in the little cut out infront of the air box where the ram air tube use to be. You can't reuse the tube because the heat exchanger hoses are in the way. The temp inside the box can get up to 160 degree while you not moving. Once you get it install you will see what I'm talking about.
Old 02-08-2009, 01:16 PM
ABALONE's Avatar
Ok, then I think I misunderstood you, now I see your point But I still think a part of this will be solved with a bigger heat exchanger, cause if you have a better circulation and a powerful pump you will get the temp on the water to decrease and there by the temp on/in the charger to decrease and finally a much cooler system even when you are not moving and no air is passing the exchanger. Just my 2 cents
I'm going to buy a set of those twin-air boxes and have them installed instead of the single air-box. VRP hade a great price on them including K&N filters! Next problem will be the engine cover? Guess the E430 covers won't fit? Well, that will be sorted out later on...
Old 02-08-2009, 01:18 PM
ABALONE's Avatar
Thanks! I sure will
BTW, thats a mean looking W210 you have in your avatar, do you have more pics of it?
Old 02-08-2009, 03:13 PM
The E430 cover will have to be modified to fit but it look very nice over the SC.
Old 02-08-2009, 04:05 PM
ABALONE's Avatar
Attachment 149198
Yes looks great!! But will it fit over the twin-airbox from a W211? Or do I have to go with the "Style 63" V-engine cover?
Old 02-08-2009, 06:36 PM
Fabio D's Avatar
210 55
NIIIIIICEEEE!!! Ab you can go too with the ML55 modify engine cover & get a real good look! in a forced induction engines the airbox/filters not affect much the engine performance/power!
Fabio Daniel
Old 02-08-2009, 07:37 PM
suicidal4life's Avatar
2001 E430
Fabio Daniel
I was going to mention that. I think E55cent used the ML55 cover on his HPS supercharged E55 so the engine cover would still say "AMG" instead of "Mercedes" like the E430 cover does.
Old 02-08-2009, 08:31 PM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Wow man, congrats!!!
Now keep us updated with pics
Old 02-09-2009, 11:31 PM
ob1kenobi's Avatar
moon buggy
Congratulations ABALONE. Keep us posted on the Kleemann installation
progress.
Maybe you can beat that Saab now
Old 02-10-2009, 12:06 AM
SleepersRock's Avatar
2008 W211 E63
Man those pics gave me that tingly X-mas morning feeling when you get whenever that perfect gift gets opened!
Old 02-10-2009, 06:49 AM
ABALONE's Avatar
Yes,hopefully! But he might have done something with it during the winter, so one can never be sure
Old 02-10-2009, 06:54 AM
ABALONE's Avatar
One little update.
I just bought a set of twin-air boxes from the E55 Kompressor with K&N filters and think that will be a better solution then the single airbox that came in the Kleemann kit.
I will also have a company make a bigger/better heat exchanger to get the temp down. I think these to mods will make this kit really "come to live"
Heat isn't a good thing, and I hope and now from a friend this will reduce the temp with about 20 degrees celsius.
Magnus
Old 02-10-2009, 01:10 PM
RAFFIE55's Avatar
Used to drive E55
Looks Great!
For us poor people we will just have to sit back and wait for results after you are done
Old 02-10-2009, 05:32 PM
Out Of Control!
JamE55's Avatar
Congrats Magnus!
That s/c looks so good. Are you going to put some A1 steaksauce on it?
Old 02-10-2009, 05:53 PM
Anyone notice kleemann changed their number on the Kompressor kit and other performance stuff? These number are more realistic. The previous number were bogus
http://www.kleemann.dk/Performance/Engines/V8M113.aspx
Old 02-11-2009, 09:26 AM
gikser's Avatar
im sorry but i have to ask? how much$$$$
Old 02-11-2009, 02:00 PM
ABALONE's Avatar
So what happend to the K4? They forgot to add full exhaust to that line up
And the "500" prefix, is that a 55 engine or is it a 500E Engine?
Old 02-11-2009, 09:13 PM
45acp's Avatar
BMW
Thanks! I sure will
hopefully soon when the weather gets better
One little update.
Magnus
sounds good man! i don't think i'd have the restraint like you to wait until march to install the goods if those boxes were sitting anywhere near me
i wonder if vrp's w211 cf airbox would fit in a w210
Old 02-12-2009, 04:49 AM
ABALONE's Avatar
Let me know when you've taken some pics!
The reason for the wait is that we have winter here now So a couple of weeks and we can start with the installation?
Yes, the VRP W211 boxes are on the way home to me, and they will fit with a few modifications.
Old 02-12-2009, 10:35 AM
Out Of Control!
JamE55's Avatar
K4/K5 are for certain exlusive customers only. LOL
Wise choice. Gives it a more "upbeat" look.
Old 03-27-2009, 11:38 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
Any Updates???
April is almost here and it's been over a month now, I'm eagered to see what the results are of the new Kleemann Kit installed.
Quick Reply: KLEEMANN SUPERCHARGER PICS&PROJECT in my W210 E55 AMG
