Thinking about selling the s/c
reasons for thinking about selling, already busted a piston, transmission is starting to go now, going to law school in the fall.
Looks like that price was only until end of 2008...
Edit: You are the second owner correct? How many miles does it have on the set-up?
Yes, I am the second owner of this set-up. First owner put about 12k miles on it and I've had it on for about 15k miles, therefore it's got about 27 k miles on the set-up give or take.
Congrats Jeff - You will own many a fine car in the days ahead!
PDC
kansascity-criminal-attorney.com
PDC
I know it will be worth it in the end; but it'll be tough to make all the ends meet. Thanks for the vote of confidence!
http://www.benzworld.org/forums/sale...ew-3500-a.html
Might be better off selling the whole car. The labor to do the uninstall, re-install, and tuning is probably higher than the cost of the S/C at this point. I thought about putting one on, and while I might not mind paying say $3-$5k for the unit, and could probably do the install myself, I don't want to have to go find a tuner (not many in the southeast) and pay out the wazz to get it tuned (on top of all the hours doing the install).
Did you flush the transmission fluid, btw? That may help. The transmission should be able to handle a ton of torque, and even with the S/C, shouldn't be going bad.
I had similar symptoms on my CLK320: same tranny, well under half the torque. Granted, not as bad as your symptoms. But I did get small surges and hard downshifts and 1 to 2 shifts. I put in new tranny fluid (flushed, then flushed again, since I didn't flush the torque converter) and the problems went away. Hope that might help, as it's a cheap fix.
If you don't like it... go get your TCU re-tuned to smooth, silky, slow shifts.
You said "silkly"
I think you should put in a good word for me to take on your current job. I live right down the street.
