time chain noise ?
time chain noise ?
hi all
my 1999 e55 120,000 miles on mobile 1 on cold start has a loud noise i think is timing chain almost goes away when warm have replaced t/chain tensioner & idler pully no change in noise also can new chain be rolled on thanks.
regards
george
regards
george
hi saintz
appears to b coming from rocker cover area at front noise is a clack clack hard to describe my self & mec. are thinking t/chain going to pull r/covers off & check chain/ guides ect. not a lot of e55 in australia & cannot find out if t/chain can b rolled on as in many other engines.
regards
george
regards
george
Generally the M113's clack sounds are provided by the valve lifters.. you can replace the timing chain (120 k on it need to change) but if the sound still in your engine you can replace your 24 small lifters & solve this issue
Fabio Daniel
Fabio Daniel
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Did you measure how much stretch you had in your chain?
Most of the time a new tensioner/spring will take that 5 hit chain clack out on cold start. Good job rolling the new one in, did you use a lock clip or peen the master link closed?
2020 E 300 Coupe and 2019 GLS 400
I used to hear the same noise, it appears to be coming from the valves cover on both sides.
I solved my issue By changing the oil, it was old and the car was garaged for 4 months.
Good luck,
Faiz
Good luck,
Faiz
