Fast help please *Anyone with W211 Airboxes on a (N/A W210,W208) M113 V8*
Old May 2, 2009 | 02:06 PM
ABALONE's Avatar
2001: Supercharged E55 AMG
Hi!
I got a call from the guy whi is mounting the S/C. And they are going to install the W211 E55K Twin-airboxes on my W210. He told me that there where not enough space between the MAF and the bulkhead (Correct name?) So he wonders if there should be any distance thing or so, so that the Y-pipe can't fit in there Anyone who has a pic or have done this?
Thanks in advance!!!!!
Old May 3, 2009 | 11:32 AM
ABALONE's Avatar
I did a pic on what it is that makes it not fit. The pipe is where the cooling water runs through and it seems as if you need a intake with a different bend so it can come around these pipe where the water runs through.
Old May 3, 2009 | 11:56 AM
armaniE55's Avatar
2012 CLS63 AMG
Wish I could help... Good Luck:
-Armani
Old May 3, 2009 | 12:13 PM
ABALONE's Avatar
-Armani
Thanks!
Yes i really want to find a solution so that the twin-airboxes can fit. If not i guess the single airbox from Kleemann will take place
Old May 3, 2009 | 04:33 PM
suicidal4life's Avatar
2001 E430
You may want to contact Blackbenzz. He had a 55K airbox on his Kleemann SC'd CLK55 before changing to a completely custom air intake.
Old May 3, 2009 | 05:01 PM
ABALONE's Avatar
Thanks, but i've already been in contact with him. He said that the MAF needed a bit of cutting in the plastic. But i'm not sure that it will do the trick in a W210 E55 engine bay, cause i think it's a bit smaller/tighter in our 55's engines compared to the longer W208 CLK55 hood
Old May 4, 2009 | 04:43 AM
ABALONE's Avatar
Old May 4, 2009 | 10:11 PM
45acp's Avatar
BMW
wow thats a tight fit
the 211 y-pipe doesn't fit in there at all? is it metal or silicone/rubber?
Old May 4, 2009 | 11:42 PM
ob1kenobi's Avatar
moon buggy
Have you contacted Kleemann? I'm sure they've been asked about this problem
before.
What about Peter and Jeff? (W210 E55K owners in this forum) Hopefully they
can give you a good direction on how to fix this.
good luck.
Old May 5, 2009 | 08:20 AM
ABALONE's Avatar
before.
good luck.
Yes, i've been in contact with Kleemann, great support
Seems like the installer solved the problem before i contacted Kleemann, so i'm glad that i can run these W211 E55 twin-boxes Getting the car on Friday
Old May 5, 2009 | 08:58 AM
MR888's Avatar
E55
So how much HP is this baby gonna put out when complete?
Old May 5, 2009 | 10:32 AM
JamE55's Avatar
Out Of Control!
Congrats Magnus on your installer getting it to fit!
Old May 5, 2009 | 10:43 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Did he just mount the MAF in the Y tube at the Y?
You should keep it at a point of highest intake velocity.
Good luck, Dyno on Fri?
Old May 5, 2009 | 01:29 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Hi!
HAHA!! told you so
Old May 5, 2009 | 02:43 PM
ABALONE's Avatar
Originally Posted by Peter_02AMG
HAHA!! told you so
Havn't installed the single airbox so i can't say it became hot like you said If thats what you meant
W211 airboxes are for the looks only
Old May 5, 2009 | 02:44 PM
ABALONE's Avatar
Old May 5, 2009 | 02:49 PM
ABALONE's Avatar
Not really sure, i guess he did it like it was supposed to be mounted. I'll have to check when i get the car.
No, no time for dyno on Friday. Going to drive it for a couple of KM so that the car adapts to the S/C being installed. Thanks!
Old May 5, 2009 | 02:55 PM
ABALONE's Avatar
If i knew that i'd tell you
My goals are crank 500+ HP 700+NM and 118-120 mph at the 1/4 strip
Really interested to see how the W211 airboxes combined with the double Kleemann heat exchanger will do. I think it will add a few more HP, at least the double heat exchanger
Old May 5, 2009 | 03:10 PM
I told you the W211 airbox won't fit the W210 engine bay. I try it, only way they told me it would fit is for you to modify the fire wall. Bent it inward, that what Mercedes tech told me.
Old May 5, 2009 | 03:14 PM
You be lucky if you get 520bhp!
I have the same set up as you do but my SC was running a 2.5" pulley which make 9.2 psi (stock 2.8" make 6.2psi) and i bearly making 520bhp. Good Luck!
Old May 5, 2009 | 03:22 PM
ABALONE's Avatar
Ok, must have missed that one. Well, now it fits without modifying the firewall, just took some time to sort it out
Old May 5, 2009 | 03:34 PM
ABALONE's Avatar
You didn't have the Kleemann headers on you car when you dynoed it
And i'm running 99 Octane fuel and have custom heat exchanger and W211 airbox, so we are not running the same setup
Also keep in mind that my car ran 112 Mph on 1/4 in it's N/A setup, thats aprox 420 HP, so add a charger and all my other mods and i see no problem in reaching 520 HP
And just because your car didn't reach 0.5 bar (7,15 psi) with the stock 2,8" pulley doesn't mean that my or any other car don't reach it
Boost isn't everything
Old May 5, 2009 | 04:16 PM
ob1kenobi's Avatar
moon buggy
How did he do it? Did he have to fabricate an extender tube to
clear the tubing?
Can't wait to see the results.
Post a new video when you have it screamming with the new S/C!!! thanks.
Old May 5, 2009 | 04:28 PM
ABALONE's Avatar
clear the tubing?
I'm really now sure, he said he made it fit and after that i stopped listen
Yes, MANY videos to come during the summer, i promise
Old May 5, 2009 | 04:54 PM
LeeRod80's Avatar
99 E55 AMG
CONGRATS BRO!!
