alternative powerteering fluid for e55???
Old May 16, 2009 | 11:32 PM
pinoyk20's Avatar
99 model w210 e55 amg
hi guys! what other brands of power steering fluid can i use on the e55? also what are the specs of the MB PS fluid si i can check if other brands has the same specs... the prob is im from philippines and i live far away from the MB dealership so i have to look for shops closer to me that has powersteering fluid that will work on the e55..... thanks!
Old May 17, 2009 | 04:11 AM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
Pentosin 11S works fine.
Old May 17, 2009 | 12:42 PM
pinoyk20's Avatar
any other available brnads like mobil 1, motul etc......
Old May 17, 2009 | 02:58 PM
Fabio D's Avatar
210 55
In our coutry is recommended the Mobil 1 Syntec red ATF & Hidraulic mechanism, works perfect
Fabio Daniel
Old May 17, 2009 | 03:39 PM
pinoyk20's Avatar
hi fabio whats the specs on the mobil 1 syntec? thanks!!
Old May 17, 2009 | 05:18 PM
Esh's Avatar
Esh
E55
try a google search, turns up everything you could want on Mobil 1 synthetic atf.
http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
Old May 17, 2009 | 05:28 PM
Fabio D's Avatar
210 55
Here we go! :
Specs: http://www.mobil.com/USA-English/Lub...thetic_ATF.asp
Type: http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
Fabio Daniel
Old Jun 10, 2009 | 08:45 AM
jmgracing's Avatar
2001 E55 AMG
You can try AMSOIL.
http://www.lubedealer.com/syntheticproil/
https://www.amsoil.com/storefront/de...aspx?zo=479407
Old Jun 18, 2009 | 07:53 PM
vice m. ilagan's Avatar
99 w210 e55 amg,honda crv,dc2 type r turbo
go to autohann
in bf paranaque they have everything you need for your e55 oil, fluid,sparplug,kleeman.
Old Jun 18, 2009 | 11:00 PM
mysticblu999's Avatar
Mercedes AMG
Amsoil is good stuff, I run it in my turbo bike.
Old Jun 19, 2009 | 02:50 PM
pinoyk20's Avatar
WOW who are you? why are you using my name and my car profile? just wonderin...... hmmm sory for the off topic
Old Jun 20, 2009 | 03:56 AM
daytonabeach's Avatar
S212 2014 220 CDI
Anybodu know if that Mobil 1 can be used with a W210 1996 E230 stationwagon for power steering?
My MB dealer sold me a can of 235.10 tranny fluid yesterday for 60$ a litre, does that sound correct to any of you?
Old Jun 20, 2009 | 08:55 PM
Fabio D's Avatar
210 55
Go to the other thread..: https://mbworld.org/forums/w210-amg/...ing-fluid.html
& yes, you can use the M1 Syntetic ATF, but you can't mix the Syntetic M1 with the white factory oil.. you need to flush the system & put them the new oil
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
