puff of blue smoke after starting my e55
Old Oct 30, 2009 | 06:48 PM
amgalex's Avatar
00 e55
Is a puff of blue smoke normal during a start up?
I noticed this before after the car has been sitting for a while, but its only been one day and I noticed it..
What can be the cause?
Old Oct 30, 2009 | 09:54 PM
Fabio D's Avatar
210 55
Check whan your car is cold in the morning, before start, your engine oil nivel.. one time ago my car has a a little more oil than MAX & made this issue at start up's
Check that
Fabio Daniel
Old Oct 30, 2009 | 10:06 PM
amgalex's Avatar
00 e55
Check that
Fabio Daniel
Thanks for the suggestion but laready checked it, level is fine.
Old Oct 30, 2009 | 10:58 PM
Fabio D's Avatar
210 55
Well. in our workshop we have some experience with the M112/M113 about the oil smoke.. if you only shows the blue smoke one time & no more. probably ur intake plenum/manifold have some amount of oil inside & enter to one cilinder by the intake valve (stayed opened) when you turn of your engine & stay away.. but if you see the blue smoke again & again & again probably you need to replace your piston rings & valve seals.. is no good to hear about this work, i know... but maybe you can remove & clean them up all your intake manifold removing the inside oil before made any major job!
Take care
Fabio Daniel
Old Oct 31, 2009 | 05:50 AM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Upgrade your oil to a thicker/higher quality oil that is less likely to burn (RP almost never burns unless its a piston ring issue). Next, do a BG full injector cleaning service, this will clean out all the gunk in your system as well as clean the valves & combustion cylinders. If these don't address the issues then you can be more concerned, but for now try those and report back.
Old Oct 31, 2009 | 05:12 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
WOT the car! Need to clean up them pipes!
Old Oct 31, 2009 | 05:45 PM
saintz's Avatar
GL450
Do you have good power now, or are you still running slow? A compression check might be in order if it's slow and burning oil.
Old Nov 10, 2009 | 12:24 AM
Lawrence1's Avatar
2011 G55 + others
how many miles on the car?if high mileage you might be seeing either some normal wear on the rings or the best case scenario ... the rings are somewhat gunked up ... i would run a high detergent oil(HDEO oil like Rotella 5W40 Synhtetic, or Mobil 1 Truck and Suv/Delvac 1 5w40 for 2-3 cycles and/or a treatment of AutoRX.
what oil are you using now, if you don't mind me asking?
Old Nov 10, 2009 | 01:56 AM
amgalex's Avatar
00 e55
IM using Platinum Pennzoil 5w-30
116,000mi
Old Nov 10, 2009 | 02:01 AM
amgalex's Avatar
00 e55
Still battling the stupid problem, although ,,, last thing i did was spray some wd30 inside the egr valve and mess around with vacuum tubes. SO far for the last week no fuel subtraction by the ecu and car runs strong , i Posted a video of a 1/4mi run. My fingers crossed on the ecu subtracting fuel.. I still have a rough or lumpy idle on the car that I can not pinpoint though....
