Stock 74mm Vs 82mm TB comparison
74mm Vs 82mm
And the new port matched S/C inlet.
Old 74mm inlet
New 82mm inlet
But is a cool upgrade for the E55's
Fabio Daniel
Yes it's a 82mm TB from the new 550 models. Like Fabio said, you need to upgrade the intake manifold to make it fit.
But the wiring/connector is all bolt on, just plug and play
but mine #: "113 141 00 25", it has different connector & pins(Round Head), do you think it well easy to change the connector only...??
ZAYED,,
ZAYED,,
Do you have a F/I or N/A setup with your 82mm TB?
Good luck!
So, also, it looks like the wiring is plug and play?? Anyone know for sure?
Thankss
ZAYED,,
Do you try to put M273 Air Mass..!??, i think its also bigger than M113 Dia, but im not sure about the connector pins......?!?!
ZAYED,,
In your opinion;- is it possible to making a Y type adaptor & put "2" of M273 TBs....? if yes, what kind of Electrical connector needs to joint
the "2" TBs together...?? and is that well effect with air mass ratio voltage).....!!!
ZAYED,,
Fabio Daniel
Fabio Daniel
Thankss for that info. Fabio, i take this theory from all new M156 63s AMG, it uses "2" TBs, with ME 9.7 ECU,, if you notice; when Kleemann
puts there Kompressor in any of M113s; they uses a small Resistor to fool the Air mass ratio signal Voltage goes & return from the ECU.........!!
ZAYED,,
