Bucking and Surging
2000 E55 2005 ML500 Sport
Bucking and Surging
My 2000 E55 with 94K is experiencing a problem with bucking and surging. The first time it happened I was sitting at a stop sign took a left punched it and it bucked and surged. The second time I was on a hill took a right punched it and it did the same thing. The other day I took advantage of an opening in traffic punched it and it did it again. Yesterday morning while getting on the freeway I punched it and it happened. After searching the archives here I think I might have a problem with the splash bowl in the tank, fuel filter or the MAF. Looking at the PO records it look like the fuel filter, spark plugs and MAF were replaced at 65K along with an injector cleaning all performed at the dealer. Please share your thoughts.
Thank in advance.
Tdog
Thank in advance.
Tdog
RE: Bucking and Surging
I did the soft reset and the problem still exists. It only happens when I go WOT, it starts around 3500 rpms. I also tried all of the transmission modes W/S with and without the ESP. Could it be the kick down switch? I'll look at the air filter and find the DIY for cleaning the MAF. If the MAF was dirty would the check engine light come on? To date it hasn't so I don't understand how this could be happening without the check engine light coming on.
Tdog
Tdog
GL450
I would consider a new TPS if you're having issues with WOT and hitting the kickdown switch. After you go WOT, does your cruise control still work?
MAF can be dirty and not throw a CEL. It's old enough it could be bad again.
GL
keep us posted
Armani
2003 S210 3.8L Brabus wagon
Try crank positioning sensor at top rear of motor. Its about $40 bucks and ten minutes of your time. These periodically go bad and can cause some of what you are dealing with. Anyway its cheap enough insurance to do. Is the battery fully charged as well. Gel batteries are good typically for 6-9 years depending on service load and standards are 4-6 depending on same. These motors require alot of juice to run properly. Just some other thoughts.
W210 01 E55
pour 1-2 cans of seafoam in your gas tank and run the car hard for the whole tank, see if that gets rid of most of the issues. Could be a dirty clogged injector based on what you are describing. Seafoam should help alleviate the problem but interplexor is correct... it is merely masking the problem, not solving it, once tanks gets low again problem will resurface.
2001 E55 - 2008 CLS63 -2016 F-150
sorry op not tryin to jak yer thread .
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
i wonder if the sea foam would help get the hiccups out of my car as it gets this weird surging at a stop light/ complete stop every once in a while as if im giving it gas but my foot is on the brake. somtimes i put it in nuetral ,give it gas and it clears but does it again after a day or two .. and no CEL ..peterAMg said it could be egr valve but havnt really checked it yet
Armani
Techron does roughly the same thing but seafoam is extremely concentrated and should be more effective. Using Chevron gas really does keep the engine running cleaner over the long run (you still gotta mash the gas every once in a while to get all the carbon out).
Also, just b/c you replaced the MAS 30k+ ago does not mean its not bad. The most common side effect of bad MAS is rough & jerky shifting with inconsistent unsmooth throttle acceleration. If you are cleaning the MAS, how are you doing it? If you are doing it with CRC spray it may make the matters worse. 91% isopropyl & q-tips are the optimum way of gently cleaning it (remember to clean the plug contacts as well, not just the sensor). Hope that helps.
I’m using Chevron gas already so adding Techron at the next fill will be a no brainer. I’ll also be able to see if the problem still exists.
Thanks again for the support!
Tdog
Tdog
1999 E 55 AMG
I have the same issue with my tank. I still dont know what it is, but i cannot go past 1/4 tank or else my fuel pump starves for gas. I ended up pulling the tank and trying to look around in it, but found only a few pieces of my filler neck (previous owner i guess liked to ram the nozzle into the tank). Tank was otherwise perfectly clean. I tried to look at the splash bowl, but it was to hard to see anything. I may have something still lodged in my spashbowl, but i dont think i want to take out my tank again to figure it out-- once was bad enough. PLUS i called the dealer and they said that the tank is not serviceable, so a replacement of the tank was like 800$ in parts.
