e55 strait pipes
Old May 22, 2010 | 08:11 PM
longmeats's Avatar
w210 e55
e55 strait pipes
Does anyone here have strait pipes instead of a x- pipe?.........I just bought an eisenman race exhaust and was going cut my resonator out...my guy said 2 do. The str8t pipes.........wuts the difference between them?
Old May 22, 2010 | 09:53 PM
JamE55's Avatar
Out Of Control!
I have straight pipes. Not really sure but i think the X-pipe is about the same as far as sound.
Old May 22, 2010 | 10:57 PM
Fabio D's Avatar
210 55
Nope.. the X pipe equal the (-) negative pressure in the 2 banks, maybe you canot feel the difference between the stright pipes instead the X pipe, cause in a 350hp engine you cant feel a real difference with 2 or 3 more HP's but the X pipe works a lot better (technically)
Fabio Daniel
Old May 23, 2010 | 02:46 AM
MR888's Avatar
E55
I have the Xpipe instead of the resonator and straight pipes instead of the secondary cats, it sounds mean
Old May 23, 2010 | 10:36 PM
Fabio D's Avatar
210 55
MR888, you can get goodness result making some change to your system . put the Xpipe in the 2dary cats place & put the straight pipes in the resonator place
The Xpipe need to be placed as short as possible to the exhaust manifolds (best place in our cars is the secondary cats)
Fabio Daniel
Old May 24, 2010 | 05:31 AM
longmeats's Avatar
w210 e55
Do u have any video clips of ur exhaust?.....ur exhaust setup sounds good>...tuesday i am going bring my car in to get the this work done everything custom made.....where did u make the cut in ur exhaust?....and will any check lights go on in the cluster?
Old May 24, 2010 | 05:49 PM
kanno's Avatar
00 E55 AMG
im gonna go with X-pipe inplace of resonator and do Dual cherrybomb glasspacks for quad tips setup in couple weeks as soon as i can find OEM amg tips that have straight inlets (not curved up like all of them)
Old May 24, 2010 | 06:25 PM
longmeats's Avatar
w210 e55
does anyone have the exhaust setup that fabio d is talking about?
Old May 24, 2010 | 09:10 PM
Fabio D's Avatar
210 55
IS NOT MY CAR! but the sens is the same
This is the most efective sequence (with hi flow primarys for best)
Forgot to tell u. my car is an euro spec with 2 O2's sensors only (no CEL in the cluster when you mod the exhaust after cats) some US spec cars have 4 O2's sensors, if is this your case maybe you got a CEL with moded exhaust cause the ME detect a faulty ambient fumes.. if you have 2 O2's only no worry about
Fabio Daniel
Attached Thumbnails e55 strait  pipes-pipes-1.jpg   e55 strait  pipes-pipes-2.jpg
Old May 24, 2010 | 10:57 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
if you just do straight pipes with no X-pipe, you will make less power than if you do with X-pipe.
The picture fabio included is actually a good setup, mandrel bent w/ X-pipe and no 2nd cats. Granted it will probably sound decently loud and drone may be slightly an issue. But all things considered its probably the best way to make the most power out of the OEM system (that plus high flow primary cats).
Old May 24, 2010 | 11:24 PM
longmeats's Avatar
w210 e55
So the best thing 2 do is 2 put an x pipe where secory cats r. And. Do. Strait pipes. Frome x pipe 2 the eissenman. Exhaust? ......everything is gonna be made custom
Old May 25, 2010 | 02:46 AM
longmeats's Avatar
w210 e55
i didnt observe any o2 sensors in the secondary cats...where should they be...also any suggestions 2 wut high flow primarysi should get
Old May 25, 2010 | 12:39 PM
AMG
O2s are only before / after primaries, no O2s on secondaries so you can do whatever you want with secondaries. Get a nice 300-cell metal core high flow cat (it will ensure no CEL issues). If you put X-pipe where 2nd cats are you should get very good results (although it will be on the loud side)...
Old May 25, 2010 | 09:21 PM
longmeats's Avatar
w210 e55
Thanks 4 the help guys i left the car at the shop earlier..gonna pick up tmrw..
Old May 26, 2010 | 10:21 PM
Fabio D's Avatar
210 55
Take some pics bro
Fabio Daniel
Old Jun 22, 2010 | 05:13 PM
mandrewlt250r's Avatar
300sd 300td e55
How many horses will u gain doing this anyone?
Old Jun 22, 2010 | 08:06 PM
AMG
X-pipe alone made 8wheel HP on the top end on a loading dyno. High flow cats make about 10HP/12TQ @ wheels on dyno. But the bulk of the gains are in the headers. The W210 headers really transform the car, nothing else comes even close. Xpipe+cats+ECU doesn't even give the power gains of Headers alone.... it really does transform the car.
The best route is to simply do Stage 4 (headers, pulley, cats/x-pipe, ECU). If you do all that the car will be seriously quick, and it doesn't cost much to do everything, probably under $2k total for parts. Used to be back in the day that would cost almost $5k
