Valve cover gaskets?
Old Mar 26, 2011 | 06:17 PM
Anatoly's Avatar
2001 E55 AMG
Does it really take 6+ hours to replace the valve cover gaskets? Anyone have DIY?
Thanks in advance!
Old Mar 26, 2011 | 07:08 PM
suicidal4life's Avatar
2001 E430
http://www.benzworld.org/forums/w210...er-gasket.html
Old Mar 26, 2011 | 10:21 PM
desired_speeds's Avatar
2007 SL55 AMG
takes about an hour and a half
Old Mar 26, 2011 | 11:16 PM
Anatoly's Avatar
2001 E55 AMG
Thank you! you guys are awesome!
Old Mar 27, 2011 | 02:52 PM
Fabio D's Avatar
210 55
45min - 1 hour max
Fabio Daniel
Old Mar 27, 2011 | 03:49 PM
Anatoly's Avatar
2001 E55 AMG
^ Thank you! The reason I asked is because my local shop quoted me 8 hours of work lol I had the biggest "WTF" face ... They probably miss understood between Valve cover gaskets and head gaskets
Old Mar 27, 2011 | 09:12 PM
2007 SL55 AMG
find another shop. where are you located?
Old Mar 29, 2011 | 11:42 PM
Anatoly's Avatar
2001 E55 AMG
Medford OR.
Old Mar 30, 2011 | 09:21 AM
saintz's Avatar
GL450
That sounds more like a quote for a head gasket.
You probably don't need to replace them if they are leaking. First, see if the bolts are loose and retighten and clean the oil. Only if they are already tight or if they keep leaking do they really need to be changed.
There are also two issues. The valve covers have a gasket. On top of them in the back, there are breather covers. These do not have a gasket, but instead are sealed with liquid gasket. If these leak, you just need new liquid gasket, not an actual part.
Old Mar 30, 2011 | 12:28 PM
Anatoly's Avatar
2001 E55 AMG
^ I was thinking to replace them anyways, since it's not an expensive fix. I still got to do my spark plugs .... lol
