Transmission service
Further, it is now suspected that by only draining 3 quarts and then refilling with the latest .14 MB fluid, transmission failure is imminent within 10,000 miles. It's better to change out as much as you can.
I have heard of some people that have tried the fill-it-as-you-flush-it method which works great but can use 15 quarts or more during the flush. You basically disconnect the lower coolant line and extend a hose to a bucket. Run the engine until it stops pumping fluid out and refill with equivalent amount of new fluid. Keep doing this until the fluid coming out is clean. Run the selector through the positions, flush once more, then top off.
I'm sure that people have had terrible experiences art the dealership but not all dealerships are the same...
So if I read one of the above posts correctly, for the W210, is a flush recommended every 2years, and is that a DIY job?
Tks.
Tks.
Here is one guy who did the 7G without too much trouble.
https://mbworld.org/forums/c-class-w...ce-thread.html
OH, and here is a good writeup on the w210 trans.
https://mbworld.org/forums/w210-amg/...questions.html
