Once again oil all over front of engine HELP!
Old Dec 13, 2011 | 06:16 PM
amgalex's Avatar
00 e55
This happened last year as well, when temperatures dropped bellow 10f
Opened the hood for routine oil level check and oil is all over got carried everywhere by the fan , its all over the belt and all front accessories.
Last year my belt slipped off and got shredded to pieces because of the oil all over it and it almost overheated my engine, this year i got lucky and caught it in time.
The cause last year was wasn't exactly known, but a oil pressure relief was changed as well as gasket under the oil filter housing...
SO now I'm lost as to why this is happening when it gets cold outside and what is causing.
Ideas?
Old Dec 15, 2011 | 03:37 PM
amgalex's Avatar
00 e55
this forum iss sslow
Old Dec 15, 2011 | 11:11 PM
Drewloera's Avatar
2000 w210 E55
I notice slightly more oil around the belt area. Seems it is being splashed around.
Old Dec 19, 2011 | 11:31 AM
saintz's Avatar
GL450
Try cleaning it off and then take a picture a little while later. Look for seepage so you can see where it is coming from. My guess is normally that the valve cover gasket is the worst offender, but would need to see on your engine.
Old Dec 20, 2011 | 12:47 PM
Drewloera's Avatar
2000 w210 E55
I also notice right bank of engine gets more oil buildup than the left side. Especially over the ignition coils...?
Old Dec 20, 2011 | 01:19 PM
novae500's Avatar
W211
def bad valve cover gaskets causing the leak?? very common issue on the E class. Both of my cars got valve cover replacements, 35k and 50k miles.
Old Dec 20, 2011 | 01:32 PM
Drewloera's Avatar
2000 w210 E55
Is it a pretty simple task to do on my own... Or should I take her in to have it done.
Old Dec 21, 2011 | 03:31 PM
amgalex's Avatar
00 e55
I don't think this is a slow valve cover gasket leak. This seems like more of a burst of oil when temperatures are really cold outside. My accessory belt was soaked in oil, it was splashed all over, radiator, engine cover etc..
Old Dec 21, 2011 | 03:37 PM
desired_speeds's Avatar
2007 SL55 AMG
do you know if its coming from somewhere on the lower engine area or is it coming from the top. Also, are you the one running an AMS crank pulley?
Old Dec 21, 2011 | 04:15 PM
Fabio D's Avatar
210 55
I think is the Oil pressure gauge port, or oil cooler seals (most common in the M112 and M113 oil leak) the other one is the crankshaft seal
Fabio Daniel
Old Dec 21, 2011 | 08:44 PM
amgalex's Avatar
00 e55
No pulley
Not sure where it's coming from ,somewhere from the front of the engine
Old Dec 23, 2011 | 10:57 AM
saintz's Avatar
GL450
If it is the valve covers, you generally don't need to replace them. Just retighten them. Not too tight, aluminum is not forgiving. It's only if they leak substantially after tightening that you need to replace them. Hope that helps someone, if not you Alex.
Old Jan 9, 2012 | 05:18 PM
amgalex's Avatar
00 e55
turns out its a pretty common oil leak: oil filter housing and oil cooler where it connects to the filter housing were both leaking pretty bad
Old Jan 11, 2012 | 12:37 AM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Yup sounds simliar to what I had..I tightened everything back up and cleaned it up and all is well
Old Jan 18, 2012 | 09:41 PM
ESTJ's Avatar
2001 E55 AMG - 2001 E320 - 1990 300CE
Oil pressure gauge port, Fabio is right.
The seal(s) that MB used here, both original and later versions were a lousy design.
Take the port off, clean thourghly, lightly apply blue RTV to both sides of the seal, apply blue RTV to the facing of the port where it mates to the block and reinstall.
Problem solved. Had to do it on mine and haven't had any problems since.
Good luck!
Old Jan 19, 2012 | 12:14 PM
Fabio D's Avatar
210 55
1+ Same on my car
Fabio Daniel
Old Jan 19, 2012 | 01:56 PM
amgalex's Avatar
00 e55
Good luck!
Thanks for the tip I think il do that
Does oil have to be drained to take port off?
Old Jan 19, 2012 | 06:48 PM
Fabio D's Avatar
210 55
Nope! no have to be drained the oil. only remove the oil port cap and you need to wait some hours to not get oil residual in the new silicone. clean all the area with some degrease, put the silicone and wait 12H+ to cure
Fabio Daniel
Old May 22, 2013 | 12:20 PM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
I'm working on this leak now, wish me luck.
NP
Old May 22, 2013 | 01:08 PM
2007 SL55 AMG
I noticed some oil under the car last week and popped the hood to see a bunch of oil all over the place in the front. I've replaced the oil cooler o rings before too.
Old Oct 24, 2014 | 12:29 AM
richmsn8888's Avatar
w211 , 2005
hi , my car year 2005 model w211 accident going up a road divider and the engine splash all over with engine oil , also my expansion tank with creamy engine oil
the work shop change the damage radiator and cooler filter , hose flushing . drive the car for 2 hours and found spilled with creamy engine oil in the expansion tank , engine temp slightly up only. whats u guys think ?
Old Oct 24, 2014 | 01:00 AM
cm60k's Avatar
Welcome aboard..,
this is 98-2002 W210 E50/E60/E55 AMG's, should to go with W211 section, here:
https://mbworld.org/forums/e-class-w211-20/,
anyway; What W211 you have..?
ZAYED,,
