Front wheel alignment / Specs
Old Mar 19, 2012 | 06:57 PM
armaniE55's Avatar
2012 CLS63 AMG
So I went in for a 4 wheel alignment everything looks good but they told me that the front camber bolt was to tight to adjust and they didn't want to strip it.
So am I ok within specs. It's not to bad off but I'm already seeing some tread getting going bad on the inner wall hence chamber.
Before -1.9
Actual -1.8
Specified Range
-1.6 -0.9
= 0.2 off
Thoughts? am I good or should I have my indy torch and get that camber bolt loose?
Old Mar 19, 2012 | 07:11 PM
armaniE55's Avatar
2012 CLS63 AMG
Pics attached
Attached Thumbnails Front wheel alignment / Specs-img_20120319_190352.jpg   Front wheel alignment / Specs-img_20120319_190400.jpg   Front wheel alignment / Specs-img_20120319_190410.jpg
Old Mar 20, 2012 | 04:50 PM
desired_speeds's Avatar
2007 SL55 AMG
camber cannot be adjusted with the camber bolt, you need the camber bolt kit from mercedes.
Old Mar 20, 2012 | 05:04 PM
armaniE55's Avatar
2012 CLS63 AMG
Hmm. do you think I'm ok though with the current alignment spec? the NTB guy told me not to worry about it that it's only .02 off.
But I have a bad case of OCD I like for everything to be perfect
Thoughts?
Old Mar 21, 2012 | 11:44 AM
slowsky's Avatar
2011 C63
armani..how's the ride with eibach pro with bilstein hd? i'm guessing the drop isn't significant enough to get a kmac kit? where did you source your parts? was labor expensive?
Old Mar 21, 2012 | 01:00 PM
Schweinhund's Avatar
W210 E55
Thoughts?
You are fine according to the acceptable range and the Camber kit only adjusts +/- 20' which is only 0.33 degrees which is minor. So you could go from -1.8 to -1.5 which may help. I'd say with that Eibach kit, your Camber looks way better than what I have seen on other dropped cars.
What's the total drop?
Old Mar 22, 2012 | 09:30 AM
armaniE55's Avatar
2012 CLS63 AMG
Beantown eh? where about?
The ride is great Bilstein HD is the stock AMG shock some have gone with the sport but as we both now that would just chatter your teeth away as it would be one hella of a bumpy ride.
Apparently you don't need to go w/the kmac kit.
see here pics of drop
https://mbworld.org/forums/w210-amg/...ook-v12-2.html
Old Mar 22, 2012 | 09:32 AM
armaniE55's Avatar
2012 CLS63 AMG
Total drop..... ? good question I can't remember but I'm running with stock pads all around. For the most part most/some AMG's have different stock pads
Thanks for the info!
Old Mar 22, 2012 | 03:10 PM
slowsky's Avatar
2011 C63
quincy area, you?
def pothole central...blew out my front 18s tires last year so riding 17s front and 18s rear this year...do you remember where you got your eibach and bilstein?
nice clean ride...drop looks perfect...my car looks like a 4x4 right now...
can you or know anyone that can do the headlight retrofit? looks amazing!
Old Mar 22, 2012 | 04:50 PM
armaniE55's Avatar
2012 CLS63 AMG
quincy area, you?
Lynnfield/ Lynn
Ouch... that story will go on and on with New England potholes. Sorry I can't remember but the Eibach I want to say Ebay and the bilstein I also can't remember just checked my gmail for invoice nada...
Thanks for the compliment. I'm selling her next Jan.
Retrofit looks amazing at night with the nice laser cut beam. Best mod to date- and hardest mod to date. My friend did the wiring and most of the work. He told me that was the last one lol. as it's really a lot of work. We also had to go in there a 2nd time which meant removing the bumper again. However it was all worth it. wish I could help you there.
Have you heard of yuppie racing in New England?
Old Mar 23, 2012 | 09:44 AM
slowsky's Avatar
2011 C63
why selling jan? saving up for cls55?
light looks amazing...i've been looking for some sort of retrofit as the stock lights are pretty weak for today's standards..
ya i'm on yuppie racing..haven't gone on in awhile..are you on there often?
Old Mar 23, 2012 | 11:42 AM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Thanks for the compliments... best mod on the car to date. It definitely makes the car look like new. The line is badas@ at night.. luv it. People always ask me what year it is and when I tell them they don't believe me probably because I was it once a month in the summer time. It also helps from Boston rock chips flying at the hood at 100mph+
Yuppie racing has a few good shows this year. Last year we did a run from boston to Mohegan Sun Casino. 50+ cars a lot of high end sports cars. You should head out this summer with us. I can check out your CF airbox
*mostly on this forum
Johnny
Old Mar 23, 2012 | 11:44 AM
armaniE55's Avatar
2012 CLS63 AMG
Slowsky
AZN Optic LEDs
I just bought a pair for my fogs. Where do yo have these connected?
Old Mar 23, 2012 | 01:14 PM
slowsky's Avatar
2011 C63
you def take great care of your car...mine on the other hand is really showing its age...at one point i wanted to move on so it became my daily/drag/winter beater...i've tried so many cars the past year and just couldn't let go of this tank...
i was on and off yuppie racing...great group of people..
azn optics i have in my city lights, license plates, and couple interiors...his leds and customer support is excellent...
Old Mar 23, 2012 | 05:59 PM
kccoop07's Avatar
2000 E55 AMG
Seeing as how this became the Boston thread, I might as well quit lurking and post! Better late than never right Armani?
Although I don't know anything about the specific camber curves of the E55, I'd generally be happier if I could get closer to 1.0°. That said, if the front tires stick and you can live with the tire wear you're seeing, there shouldn't be any other problem.
Anyway, I'm Keith, I live in Woburn, and I daily drive a well-used 2000. Here she is on winter tires:
Attached Thumbnails Front wheel alignment / Specs-e55.jpg
Old Mar 29, 2012 | 05:23 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Hey Ketih..
Didn't you stop me at a sub-shop parking lot in Woburn. Has to be? That was you correct?
Johnny
Old Mar 29, 2012 | 05:24 PM
armaniE55's Avatar
2012 CLS63 AMG
Did you do a retro fit on the Deepo's?
Old Apr 5, 2012 | 06:20 PM
kccoop07's Avatar
2000 E55 AMG
Sorry, went away to Vegas for a while.
Anyway, yep, that's me. All I've done is Plasti Dip the grille and chrome strips, smoked markers, and a full stereo. The headlights were on the car when I got it, complete with the awful "stock" projectors. I'll be looking to do a retrofit with good parts here pretty soon.
What I need to do first is exhaust. Know of any good local shops that'll do a header install plus some cat/x-pipe work?
Old Apr 20, 2012 | 09:50 PM
AZBENZ-CTSV's Avatar
PORSCHE PANAMERA TURBO LAMBORGHINI GALLARDO SL600 E55 BRABUS*SOLD*
I'm going in 4 wheel alignment as well. I have 20" brabus wheels/w fallken tires and all 4 are going bad from the inside out. I'm averaging 8k on the rears and 10k on front. I'm sure this can't be the norm
I just ordered some ventus v12 and then to alighnment shop.
Old May 8, 2012 | 04:40 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Hey bud! Hope all is well. You can look up Louies custom exhaust. I hear they do awesome work. When will your car be ready? I plan on going to a few events this summer. Care to join?
BTW - check out the AMS headers on E-bay really cheap
Johnny
Old May 13, 2012 | 12:45 PM
kccoop07's Avatar
2000 E55 AMG
Johnny
At 13 years and 120,000 miles, my car will never REALLY be ready.
I should really go talk to Lou's. My car sounds like an old pickup at this point! But I've already got a set of AMSs on the shelf here. ;-)
