+1000 Nm Tranny rebuild Pics
Old Jun 30, 2012 | 07:00 AM
ABALONE's Avatar
2001: Supercharged E55 AMG
Hello old friends, long time no see!
I thought i'd share a few pics of my new tranny build. It's going to be a really strong 722.6 tranny when it's done.
The old tranny had worn clutch packs on all gears and the friction and steel plates had blue hot spots from slipping.
The new tranny will be a special one where we will put in more clutch pack in every gear (except the rear ). The 722.6 trannys before 2002 has double side friction discs where the newer 722.6 has single side friction discs. So for modding our trannys are better as you can replace a steel plate with a friction disc I think there will be room for 8 friction discs instead of the stock that holds 6.
Upon that we will do a special valve body that will raise the oil pressure even more then only puting in the blue top solenoids (Putting in blue tops raises the pressure 10 psi alone) In these trannys it's all about pressure so that the clutch packs won't slip upon shifts and WOT.
This tranny is going to be stronger then a S/SL 65 V12 tranny I'll let you know in a week or two when the beast is out.
Here are some BIG pics (sorry) You can open the links (copy paste) in a new window and they will be smaller
Picture below is a W211 E55 Tranny with single side friction discs
The blue solenoids
Torque converter below with a double disc clutch
Old Jun 30, 2012 | 07:32 AM
cm60k's Avatar
Hey Magnus, Welcome Back,,
Thankss alot for a pics.,, always surprise me with a perfect upgrade ideas,, respect that of course,, Keep Forward........
ZAYED,,
Old Jun 30, 2012 | 10:42 AM
Velosolex's Avatar
2000SLK, 2012 Kia Forte 5
Now that is taking a transmission apart and a very clean work area. Very well done!!!!!!!
Old Jun 30, 2012 | 12:57 PM
MB_Fahrer's Avatar
Deleted
In the immortal words of Jeremy Clarkson, "mmmmmmmm!!!!"
Old Jul 1, 2012 | 03:42 AM
ABALONE's Avatar
Thanks guys!
I'll let you know how she is running with the new tranny.
// Magnus
Old Jul 1, 2012 | 12:22 PM
Fabio D's Avatar
210 55
Abalone how are you mate! you stay running the blue tops yet? or you change it by the brown top ones again?
Fabio Daniel
Old Jul 1, 2012 | 02:33 PM
ABALONE's Avatar
Fabio Daniel
Hello!
I'm fine thanks I still have the blue tops and will still have them with the new valve body.
Old Jul 1, 2012 | 09:59 PM
Fabio D's Avatar
210 55
So cool bro! if you can provide the part # by the blue top ones if i remember good they are 2 units i know you post the numbers in other thread but i can't find it. if you can please let me know
Thanks in advance Ab
Fabio Daniel
Old Jul 2, 2012 | 05:24 AM
cm60k's Avatar
As i remember they comes with #: "240 270 00 89"......
ZAYED,,
Old Jul 3, 2012 | 01:00 PM
Fabio D's Avatar
210 55
Maaaanyyy thanks bro!
Fabio Daniel
Old Jul 4, 2012 | 12:10 AM
Schweinhund's Avatar
W210 E55
GREAT pics! Looks like so much fun. How are you fitting more clutch packs in? Are they thinner?
Old Jul 4, 2012 | 03:07 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Abalone! Hope all is well. I was wondering what you were up to?
Great project! keep us posted
Old Jul 8, 2012 | 05:20 AM
ABALONE's Avatar
Thanks guys!
Almost, there are 6 discs and 6 steel plates in each pack. So we are replacing 1 or 2 of the steel plates in each pack to a thinner one, and that way we can fit 2 more friction discs in there.
Old Aug 1, 2012 | 09:59 AM
tooFATtoDRIVE's Avatar
'03 E55 Estate
Who has carried out this rebuild?
Old Aug 1, 2012 | 11:52 AM
cm60k's Avatar
Hey Magnus,,
How much approx. $$$$ that great job cost you......?!!?
ZAYED,,
