E55 with Speedshift, Paddles, M Mode and other Mods
#326
00 C200 & 00 C55 & 06 SLK55
Dennis,
I put 5.4l from W210, and run C43 ECU, without any tune, it runs great, i raced many 55's with good luck>>thankss god..,
Fabian is right, it's an optional for ECU fuel remap, but it's NOT necessary to do it, while you have ME2.0 with W5 shifter,
swapping an Engine is a good choice, if you want to go with ME2.8, you will have to get donor CLK55 to switch everything,,
lot lot lot of job>>>need relax>>OMG..
ZAYED,,
ZAYED,,
#327
one more thing:
The M113 5.5L in the car from my parents has the 4.3 injectors installed ... dont ask me why. Under full load i have a error in the ME that the self adapt is on its limit to reach lambda 1 ... i switched the injectors to the correct 5.5L injectors ... no more errorcodes and the car uses 3L less fuel!
When i installed Injectors from late 5.4l model, better start & more more acce. response..
ZAYED,,
#328
that IS correct. The Software has a self adaption. Dont know where to look for it on the ME2.0 but on the ME2.8 you can see exactly what values the self adaption uses. But it is not endless and 30% more displacement means a lot more fuel to use... i guess the self adaption would be on its limits then, that would be no option for me.
I use a modified CLK-DTM Software, the CLK-DTM has the same injectors as the M113K but now i use SLR Injectors with a higher flowrate. my self adapt values went from nearly 1 to 0.8.
greetings, Fabian
greetings, Fabian
guten tag Fabian
I'm getting confused here what to do if I should stick with c43 software after doing the engine swap or send the ecu to a tuner for E55 software update?
here's a youtube video.
If you click on Show more info + read the comments in this link you can see some people say, car will go worse and lose power with an E55 flash and the recommendation is to stick with C43 software this way ecu will adapt to engine?
Stock ECU
E55 software mapping = car lost some HP/TQ
seems like keeping the C43 software without remapping to E55 software is the best solution according to both youtube videos information.
#329
I heard many complaints with 55 remap from good experience guys,
in my case; i didn't tune my car yet, but definitely im soo pleased with the results with stock C43 ECU,,
that may concern with tuner touch it self, need very good tuner to deal with it..
ZAYED,,
ZAYED,,
#330
how is your fuel consumption with stock C43 software if you drive in normal conditions VS if you drive like a shaitan on the road with your heavy right foot on the axxelerator?
fuel tank is 62 litres. with normal driving conditions, do you get cheap gas mileage?
How far do you go on 62 litres of fuel with legal driving?
I asume E55 engine will drink more fuel because the c43 software is not correct for this engine?
How far do you go on 62 litres of fuel when driving like a car thief?
i wouldn't let an incompetent tuner touch my ecy if i had it reflashed, they would probably fukk up everything?!
#331
hmn ... at least, i never made such a modification with the original ecu so everyhing is theory but:
When you use the 4.3L Engine with its injectors the ME opens the valves for around 2-3ms. when you switch the engine to 5.5L and also install the larger injectors it should be no difference for the ME ... the ME only measures the time it opens the valves, not the output of the valve itself.
So, after a little brainstorming, i would say: yes, you can go with your original C43 software. maybe not optimal and the best way would be to get hands on a original C55 Software ... but it should work without problems as long as you use the correct infjectors for the 5.5L ME2.0 Engine! ME2.8 Engines uses different injectors, dont know if they are compatible.
greetings.
greetings.
#332
greetings.
greetings.
when i find an engine at the junkyard, they are complete with injectors
#334
#336
shu habibi
honestly; i didn't compare normal VS hard conditions for fuel consumption, not that care about it.,,
with old injectors, i'm always facing faulty O2 sensors, but after replace them to newer version, NO more O2 sensors in the ECU memory..
ZAYED,,
#337
Yeah.!, it's eating fuel a lot>>lot, i'm also using 98 RON fuel, thats helps to eat more i believe..,
ZAYED,,
ZAYED,,
i always use 95 octane as it's cheaper.
do you ever drive in normal conditions or is it always flat out 100%, do you see the gas-needle drop fast in normal conditions?
how far of distance KM do you get on full tank 62 litres with normal driving conditions?
thanks
#338
Dude ... a AMG is not supposed to save fuel...
My E430 took around 13.5L/100km, after the switch to E55 it took around 15.5L/100km (both 95 Octane) and now with the supercharged engine i am at 18.5L/100km but with 102 Octane Fuel...
Nothing comes from nothing ... if you want to save fuel you´ll need to take a C200 Diesel
#339
Dennis,
I agree with Fabian about saving fuel, most guys know they will save some $$$ in their wallet for fuel, little more fuel with correct ECU/ROM map = more power..,,
i didn't count anything about fuel consumption, that's one of my bad habit..
ZAYED,,
ZAYED,,
#340
113.944 engine for c43 amg paired with correct c43 ecu gives correct gas consumption.
113.980 engine from e55 amg paired with wrong ecu from c43 amg, what will gas consumption be like= will gas consumption increase to an abnormal use of gas or will it be the same or similar like when i had the stock c43 engine?
you are absolutely right, if you wanna save gas an AMG is the wrong car for ya!
I have the final question for engines fitted with ME2.8/EGS52 electronics.
would an E55AMG engine from 09/2001 work in my 1999 c43 amg if I removed the wire harness, ME2.0/EGS51 and throttle body from my c43 engine and fit these parts to to this E55 AMG engine from 09/2001 with ME2.8/EGS52 electronics?
Meaning I will be swapping parts between engines to fit my c43amg?
#341
The engine would use more gas, as i said in my posting above the ME opens the injectors for the time X ... 4.3L injectors have less fuel output the the 5.5L injectors so the 4.3ME will open the injectors the same time but more fuel will pass the injector. So you´ll have more fuel consumption of course, but not because of the 4.3ME.
Yes, you can take the 09/2001 Engine and use your old harness and TB, anything else should be plug ´n play.
greetings, Fabian
greetings, Fabian
#342
greetings, Fabian
greetings, Fabian
would it be any good idea to swap injectors from my c43 engine and put them on the E55 engine instead, the ME2.0 ecu might read the data more accurate and give correct fuel spray from injectors?
thanks
#343
As i remember; 98-99 E55 uses the same injectors with C43, (which is Green color),,
but MB replace them in all M113 5.4l from 00 to 2006 with bigger injectors, (which is Beige/Yellow color)..
ZAYED,,
ZAYED,,
#344
after installing the engine i have to let the engine adapt to c43 ecu when i drive my car.
is it that simple to make the engine swap and make it work correct?
#348
our friend Zayed says 98-99 E55 have the same green injectors like c43
newer version injectors are of course better with more high flow for gasoline.
maybe the older version E55 injectors might give a more accurate spray with ME2.0 from C43 ecu?
#349
That's may related to the Engine displacement, 4.2l>>5.4l, ECU could reads more fuel RON before & after, then save it to the data/file memory,
but not soo sure about that, just a THEORY..!!
ZAYED,,
ZAYED,,
#350
just checked part Numbers.
C43 (M113.944) and E55 (M113.980) Engines with ME2.0 HAVE the same Injectors.
But changing Injecors on the N/A M113 is no big deal so i would say ... if you can find a ME2.8 5.5L Engine go with that injectors, if it wont work well, switch to the C43 Injectors. I really cant say what the ME2.0 makes of it ... the only ME2.0 i ever had was in my old E430 and i am happy that i have switched to ME2.8 and then to ME2.8.1
greetings, Fabian
greetings, Fabian
