Performance Upgrades
Old Nov 3, 2014 | 07:13 AM
madmobman's Avatar
1999 w210 E55T AMG
Exclamation Performance Upgrades
Hi guys, so about a month ago I bought a E55T and I really want some more power out of it. I'm looking for idea of what to do. Also I got a big warring by the head of service dept at my local dealer about do anything to the exhaust less I want such little back pressure that my car will be creating less power. Please through in any ideas that you guys know will make it more powerful and if all, sound better. I really want to invest my time and money into it and truly make it my own.
Old Nov 3, 2014 | 09:00 AM
eFifty5AMG's Avatar
2004 E55
Starting with the exhaust would be easy. If you want bold sound, less restriction, and a little performance upgrade, go with the crossover pipe setup. I went with an X-pipe, removed secondary cats, and also removed the resonator. This will free up a little weight and sound so much better. Here's my thread https://mbworld.org/forums/w210-amg/...ipe-video.html
If you want more, you can go with a tune, some headers, a port/polish, or supercharge it (or all of the above). Look at Kleemann, pricey, but quality. Quaife LSD will get your power to the ground.
Old Nov 3, 2014 | 11:07 AM
madmobman's Avatar
1999 w210 E55T AMG
Tune? I had no idea ECU tuners are around. And thanks
Old Nov 3, 2014 | 12:08 PM
eFifty5AMG's Avatar
2004 E55
You won't get gains like a turbo'd car, but I'm pretty sure Eurocharged has a tune package for the NA 113s.
Old Nov 3, 2014 | 01:43 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Hello,
Replacing secondary cats with an X-pipe & deleting the resonator is the way to go.
Cheapest mod, yet very very effective.
To help you decide you can see my feedback here:
https://mbworld.org/forums/w210-amg/...te-x-pipe.html
However, I believe the crossover will have LESS scavenging effect in the wagon, because after the resonator the exhaust pipes merge into one.
Good luck,
Faiz
Old Nov 16, 2014 | 11:16 PM
madmobman's Avatar
1999 w210 E55T AMG
Thanks Solo wing. Also I'm wondering what kind of ECU tuning you have done.
Old Nov 17, 2014 | 02:36 AM
Solo wing's Avatar
None so far, my priority is to get a tune-up , regular maintenance before Re-commencing modding
I've heard great things about Eurocharged tuning.
Others I guess are overpriced.
Also before I get a Tune, I'd like to install Shorties and/or pulley.
Good luck
Faiz
Old Nov 17, 2014 | 11:23 AM
madmobman's Avatar
1999 w210 E55T AMG
Sorry for the odd question. I thought I came across another post form you in which you stated that you did. Thanks for the Eurocharge advice though.
Old Nov 17, 2014 | 12:06 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Good luck
Faiz
Old Nov 17, 2014 | 09:37 PM
Schweinhund's Avatar
W210 E55
Frankly, you aren't going to get huge power increases on these cars. Your best bet is to get rid of the secondary cats and resonator and add shorty headers.
What you can do right now is the ECU reset. Make sure you do this once a week. These cars have an aggressive ECU econo-tune that starts to kick in after about a week.
1. Turn off all electric loads. Lights, radio, cell phone chargers, headlights, etc.
2. Take out key, put the key in and turn to just before start. Leave it there
3. Gas pedal to floor (including the little extra push at the bottom).
4. Keeping your foot on the gas for fifteen seconds.
5. Keeping your foot on the gas, turn the key to off and leave it in there.
6. Foot off gas.
7. Remove key AFTER two minutes.
8. Drive regularly for about 2 minutes.
9. Have fun.
It doesn't always work. Sometimes, two attempts are required.
Old Nov 18, 2014 | 01:24 AM
madmobman's Avatar
1999 w210 E55T AMG
6. Foot off gas.
9. Have fun.
Thanks for the tip. I already knew about the ECU reset but I never found the detail that you gave me. Hopefully this time it will work.
Old Nov 18, 2014 | 03:27 AM
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
6. Foot off gas.
9. Have fun.
Never ever heard of such thing, what execatly should be reseted with this method? For a "eco"-Tune the whole mapping has to be changed, there is no additional "eco" mapping in the ECU. Besides, of what ECU are you talking? ME2.0 or ME2.8? Both where used in the W210 E55.
the only thing that can be reseted, via StarDiagnosis and only at ME2.8, is the self adjustment of the fuelamount, this depends on the values the O²-Sensors are measuring and is only used to get a perfect fuel/air balance. there is absolutly no need to reset that. Also there is a "Base Initialization" in this process the Throttlebody will be calibrated, but THIS can not be done without StarDiagnosis and takes around 30s to complete.
There is a Urban Legend that the TCU can be reseted in such a way, i tried this several times ... nothing happend, i verified via StarDiagnosis. Reseting the TCU means resetting the adaptions of your gearbox, that sometime can result in better shifting.
Old Nov 18, 2014 | 08:50 AM
cm60k's Avatar
100% agree with Fabian,
assuming these procedures which "Schweinhund" provided for TCU reset not ECU, i'm i right..!??!
ZAYED,,
Old Nov 18, 2014 | 09:33 AM
W210 E55
It's an ECU reset but it absolutely does affect the TCU.
I usually do the reset procedure then do a hard acceleration after a few minutes just to teach the ECU how I like to drive. :-)
And, yes, the W210 E55 ECU's aggressively start to tune towards better mileage after about a week.
Old Nov 18, 2014 | 02:53 PM
cm60k's Avatar
Don't know it's for ECU as well, Thankss for info..
ZAYED,,
Old Nov 21, 2014 | 10:19 AM
Dan04mcs's Avatar
2002 E55
Do any of the tunes availbale for the W210 E55 eleminate adaptation?
Having the ecu in "go" mode 100% of the time would be nice.
Old Nov 22, 2014 | 12:41 AM
Midwest's Avatar
2001 E55 AMG
What kind of gains could you expect with a eurocharged tune? say on a stock car, and one with headers, x pipe, deleted resonator, and a renntech bubble top airbox?
Old Nov 22, 2014 | 05:56 PM
Solo wing's Avatar
I believe No one achieved that yet. The adaptations will always return to eco values.
The ETC/TCU priority is comfort and economy. A transmission service, blue top solenoid valves, AND maybe a TCU+ECU tune would fix part of the problem
