Where can I get this T connector?
Old May 1, 2017 | 07:23 PM
trinitony's Avatar
E55 C43 993C2S
Does anyone have a part# for it? Went to Dealer today and it doesn't show up on their PET. It was the EOD so they will continue looking tomorrow. I need it ASAP.
Old May 1, 2017 | 07:48 PM
raymond g-'s Avatar
99 E320
head to your neighborhood home depot or lowes et al, hardware store and look
in specialty fastener aisle for nylon t-barb connectors. just be sure you measure
the hose ID first.
as far as I know, that is just a vacuum hose thing so as long as the connector
passes air, you should be fine. natch, if anyone feels different, jump in and
post.
Old May 1, 2017 | 08:02 PM
cm60k's Avatar
Unfortunately; MB not provide this T-piece, even with Radiator hose kit..!??!,,
i bought (8mm) universal alloy T-piece from hardware shop..
-;ZAYED;-
Old May 1, 2017 | 09:13 PM
trinitony's Avatar
E55 C43 993C2S
Thanks guys! BTW, anyone have a picture of the pressure port gasket. The one I got from the dealer this afternoon does not look like the one I removed yesterday. He said I only had two choices, one was hollow and the other filled in but with two holes.
found pix..guess it is the right part after all... http://www.benzworld.org/forums/w210...re-port-4.html
Old May 1, 2017 | 09:32 PM
E42AMG???'s Avatar
E420
I went to three different dealers before someone could find it just get something from the hardware store not worth the hassle and cost $30 oppose to $6
Old May 2, 2017 | 10:10 AM
IanB's Avatar
'99 E55t AMG
It's only available with the upper rad hose I believe, you get the upper rad hose, with the hose that runs to the T, and the hoses that run to the coolant reservoir, for a big stack of $$$. I used a vacuum T and it's held up fine for a few years now. A brass T would be a stronger piece than the plastic one I found handy, I'd go that route.
Old May 6, 2017 | 01:43 PM
trinitony's Avatar
E55 C43 993C2S
Got this at Advance Auto Parts.
Old May 8, 2017 | 09:55 AM
IanB's Avatar
'99 E55t AMG
That is EXACTLY what I used to fix mine.
