need help 👇
Old Apr 27, 2018 | 03:51 AM
Aydin Aliyev's Avatar
w210 e55
need help 👇
Hi guys I got a w210 e55 and swap engine from w220 s55 m113k supercharge Makes everting work but Ecm or Esu needs tuneup any body knows how can help me with this.
Or I think buying ECU ignition key and shifter from w220 s55. But don’t know if it’s makes my car work like it’s need ? Let me know any info from you guys I’ll be help a lot thanks
Old Apr 27, 2018 | 03:33 PM
w210 e55
Originally Posted by Plutoe
Can you start the car??
yes it’s start But run very badly to much cods
need reprograming
Old Apr 27, 2018 | 04:09 PM
ItalianJoe1's Avatar
2003 CL 600
If it starts, it's not an issue with the EIS/shifter. It should run fairly normally if everything is plugged in and working, are you sure you have a good MAF and O2 sensors? Good coils? Grounded well?
Old Apr 27, 2018 | 06:52 PM
w210 e55
there is supercharged engine now it’s doesn’t have Maf sensor I need to programming to S-class
Old Apr 27, 2018 | 07:22 PM
cm60k's Avatar
What M/Y of your E55..?,
do you know, if your ECU "ME2.0 or ME2.8"..?,,
and, do you still use stock gearbox, or S55K one..??
-;ZAYED;-
Old Apr 27, 2018 | 07:52 PM
w210 e55
-;ZAYED;-
it’s w210 2001 e55
about ECU I don’t know all I know it’s stock
yes gearbox it’s stock
Old Apr 28, 2018 | 12:49 AM
2003 CL 600
Oh, you can't run that engine with the older M/E, so you will need to have an M/E coded for the car, or do as you said and run the one from the 211 with key/EIS/shifter
Old Apr 28, 2018 | 01:09 AM
w210 e55
yes that’s should be w220 it’s engine from that !
But I don’t know if it’s really help or not!? I don’t have all that I need to buy.
2 people told me that one guy not sure if that will work other guy from kleemann he said I also need put w220 cluster with all other ting.
I need know for sure if all that will works.
If u know for sure let me know
Old Apr 28, 2018 | 05:39 PM
cm60k's Avatar
If i'm not mistaken;
your ECU won't work properly even if you program it,
you will have to use "W220 S55K" ME2.8.1, cause the S/C clutch is controlled & activated though it..!,
at the same time, have to unlocked it to match with your steering lock/EIS/key,,
also, you will have to use "55K" speed shift "722.643" gearbox, cause it's stronger & reliable,,
your stock "722.636" gearbox will not survives more enough for sure..
-;ZAYED;-
Old Apr 28, 2018 | 06:10 PM
w210 e55
-;ZAYED;-
ok I can found key ecu and shifter buts it will help?
And why I need change a cluster? If u have any idea!
Old Apr 28, 2018 | 06:19 PM
cm60k's Avatar
I think, W220 steering lock/EIS/key won't work, due to differ steering lock wiring & differ shifter set-up, for fire up authorization..!,,
what cluster..??
-;ZAYED;-
Old Apr 28, 2018 | 06:52 PM
w210 e55
what cluster..??
-;ZAYED;-
speedometer !
Old Apr 28, 2018 | 06:55 PM
cm60k's Avatar
Yeah i know; but why change cluster..?!?
-;ZAYED;-
Old Apr 28, 2018 | 07:37 PM
w210 e55
-;ZAYED;-
I don’t know! Guy from kleemann tell me that but I’m not sure if he knew for sure that!
Old Apr 29, 2018 | 09:45 AM
cm60k's Avatar
I don't think cluster should to be changed, unless if you increase the speed range only..!,,
cause in "ME2.8", with digital (km/mile) numbers, the speed should controlled via ESP module, isn't..
-;ZAYED;-
Old Apr 29, 2018 | 03:35 PM
w210 e55
-;ZAYED;-
yah I probably gonna give try find all I need and instead !
I don’t need anything for supercharger just
w220 s55 ecu right?
Old Apr 29, 2018 | 04:03 PM
cm60k's Avatar
Kinda yes,
but need good tuner to unlock it & match it with your "steering lock/EIS/key"..
-;ZAYED;-
Old Apr 29, 2018 | 04:42 PM
w210 e55
Kinda yes,
-;ZAYED;-
I think 🤔 I can find some one for this! Or go with alternate way remove lock !
Old Apr 29, 2018 | 10:42 PM
ATL_E55's Avatar
W210 E55
Why is that W220 S55 M113k swaps are preferred over the W211 E55 M113k?
Old Apr 29, 2018 | 11:28 PM
w210 e55
Originally Posted by ATL_E55
Why is that W220 S55 M113k swaps are preferred over the W210 E55 M113k?
cuz w210 e55 m113 it’s not a m113k
w210 e55 non supercharged engine!
i like w210 body e55 it’s good 349 hp not bad. ! But I like more power!
Some people can say why not to go buy other amg
like a w211 amg or w220 I can say I have a w219 cls55 amg but I wan w210 whet at leas 500 hp on
Old Apr 29, 2018 | 11:55 PM
ATL_E55's Avatar
W210 E55
Sorry I meant W211 E55 M113k vs the W220 S55 M113k. What the difference?
Old Apr 30, 2018 | 12:38 AM
cm60k's Avatar
As i know; all "M113K" Engines & gearboxes are the same,,
NO difference at all..
-;ZAYED;-
Old Apr 30, 2018 | 12:49 AM
w210 e55
ok no problem!
So w211 e55 is 469 hp and 516 torque
w220 s55 is 493 hp and 516 torque
so i don’t wanna lose any hp on my engine
yuo know people start doing everything the just for 5-10 hp and so exited for
Old Apr 30, 2018 | 01:00 AM
w210 e55
-;ZAYED;-
yes. Even my gearbox its same but not sure if it’s can hold all power
Old Apr 30, 2018 | 01:12 AM
cm60k's Avatar
I believe, this Extra (HP) due to ECU differ set-up only,,
but "M113K's" Engines & gearboxes internals are the same..!
-;ZAYED;-
