The Black Beast
Also Recaro came out this evening just didn't like the way the seat was set up (high and fixed). The Planted base is from a 996 & has been modified to fit the E55 rather than buying one that's meant for the ca and since already modified, I am keeping it.
The square tube and the recaro side braket makes you feel as if you are sitting on a toilet, too high for my taste. It's being replaced by Planted sliding mechanism and the planted side mounts, probably not as aesthetically pleasing as the Recaro's are but none the less, would serve the purpose much better
Removed the Recaro side mount and the spacer bracket, left the seat inside to go get the Planted brakets/sliding rails and the side mounts only to find out, our 6 year old has already found his spot LOL
Removing the current brakets
LOL
LOL
Well that could be fixed by drilling extra holes in the rails but this new set-up sits 2" lower than the previous set up, so not going to work
Options: I am going to call Planted to see If ordering the appropriate Mercedes W210 base plate gives me enough height or the second option, keep the current bracket and order the 2" Planted spacers?
I do like the looks of the all black Planted side mounts though
Clean up prior to the install
Looks and feels good--- Sliders makes getting in and out so much easier
Looked more tacky but didn't like it being fixed
The engine bay seems all butchered up and would like to get rid of the stupid *** stuff done to it
Going to install Speed43 box and get rid of the friggen cone air intake.
Can someone please explain to me to install the OEM air box, what do I exactly need done here (can post more pictures) if needed?
What the **** did the guy do with the passenger side of the engine bay and what are those hoses with the catch can, take it off, and if leave it in, how to tidy up the mess?
Nice car but done without any aesthetics in mind.
Just snapped these. No clue what all your hoses are for. This is stock.
Unfortunately while opening up the box, I ended up cutting the front cover as well
The finish is top line and once everything is good, I will send it back to him to refinish for me yet one more time
Gotta get rid of that Cone air filter crap.
I guess if it was done right and not just thrown it int here along with other engine stuff, I would have kept it but aesthetics was not the PO priority and that's OK too
I have a 964 Turbo as well and all these cars have different flavors, one not better than others.
Some random pictures on my drive back after picking it up and driving it back 1300 miles from CO this past weekend.
and yes, I did get pull over 98/75 mph
