Which 5mm coil spring seats for my 2002 E55 AMG?
2002 E55, 2008 Carerra S, 2012 Cayenne Base, 2017 Panamera S4
Greetings all,
My indy just replaced my shocks with Bilstein B8s and swapped the front wheel bearings. It drives like a different car now, but it needs to be lowered a bit. I really don't want to put lowering springs on it for fear of diminishing the ride and dragging the under carriage. One half to three quarters of an inch would be perfect.
I visited the local dealer and they said I need spring seats #210-321-01-84 front and rear. I entered my VIN and put this part number into this site mboemparts.com. The site says they do not fit my 02 E55.I've been searching all over the internet for what part numbers I am supposed to put on this car with little success.
I found the following in the CLK forum:
Front
210-321-01-84 5mm
Rear:
210-325-01-84 5mm
The rears are different and mboemparts.com says they do not fit either. I'm frustrated. Can anyone help and provide the part numbers for the 5mm spring seats, both front and rear that fit my 2002 E55?
Thank you,
DP
Front
210-321-01-84 5mm
Rear:
210-325-01-84 5mm
Thank you,
DP
'99 and '05 E55 AMG
Your part numbers are correct. I'll dump here what I have available. I originally collected this when in the midst of a discussion concerning which springs were on which models. Shim and spring info included in post; WIS info attached as .pdf documents.
mbwillgrubs (03-27-2024)
