First time at the strip in the E
Old May 1, 2005 | 08:13 PM
DJE55's Avatar
07 S65
This was the first trip for me and my E55 at the track. I wasn't even planning on going to the track, it was completely spur of the moment. I didn't have the front tires pumped up but I did lower the rear's to 30psi on my second pass. The track I ran at is an old run down track. We had a head wind of about 15mph and I didn't have time to try and cool the car down. The car was a little warm on both runs. I was somewhat pleased with the second run because this is known as one of the slower tracks around our area. I ran a 12.24 which isn't terrible for a bone stock car with Conti's but, the MPH was only 113. Could a head wind effect you on top end that much? I was able to get a 1.77 60' with the Conti's so that's not bad at all I don't think. Let me know what you guys think about the MPH. I just can't understand why the MPH was off that much. The first run was bad, 12.53 with a 2.04 60' but the MPH was a little better at 115. The first run I didn't even let any air out of the rear tires (36psi). Let me know what you guys think. This was the only two runs I was able to make in the car.
Derrick
Old May 1, 2005 | 08:26 PM
DerekFSU's Avatar
Sounds great to me, even your name. That 1.77 60' time on Contis is nearly amazing. 113-115 trap speeds are what my car ran bone stock.
Old May 1, 2005 | 08:39 PM
housclass's Avatar
'08 CLS63
12.20's is damn good but....
1.77 60' is awesome!!!...on stock tires. remember...the lower your 60' time is, the lower your mph will be.
put the rears to 25psi, cool the car off...keep the heater on and you should be in the 12.00's keep us posted.
great runs!
Old May 1, 2005 | 09:08 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
There are guys that would give their left ball for 1.7.....INCLUDING ME!!!!
Great times....you did great!
Old May 1, 2005 | 10:15 PM
DerekFSU's Avatar
How does that work?
Old May 1, 2005 | 11:10 PM
DJE55's Avatar
07 S65
Thanks guys. I plan on another trip out and I hope to be more prepared. I will keep you guys posted. Derek, (nice name also) as far as the 60' times being better and MPH slower. When you have a good 60' time you are covering more track quicker not faster. If your 60' time is slower you have more track to gain MPH. Don't know if that explanition makes sense but, I have noticed this in all my cars that I've ran. I just thought you guys were running higher trap speeds stock than my car.
Old May 2, 2005 | 03:40 AM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
dude 1.77 with conti's! thats a miracle! good run.
Old May 2, 2005 | 08:47 AM
cte430's Avatar
'07 Porsche 997TT
I'll be making my first run at the track in a few weeks. Question regarding tires - Would I see any significant difference if I ran either 265's or 275's in the rear? I have two sets of stock wheels, one set with PS2's (265's) and the other with SO-3's (275's). What do you think?
One more thing. Run with the heat on? Can someone explain.
Old May 2, 2005 | 09:53 AM
enzom's Avatar
2005 E55
I am not sure that it would make that much of a difference. What you gain in tread width you lose in aspect ratio. In other words, the wider the tread width the thinner the sidewall. The thinner the sidewall, the less flex - making the tires lose traction more easily.
Also, see if you can find the tread widths on Tire Rack.com or on the manufacturer's website. Not all 265's/275's have the same tread width. Could be that the actual tread widths are very close.
As far as the heat on - I guess it is intended to let some of the heat out of the engine. I used to do the same thing in my 300 ZXTT's before I ran and before I shut down. Not sure if it worked. Strangely, turning on the A/C and the recirculating fan to max in my Z06 was good for lowering coolant temps by a few degrees.
Old May 3, 2005 | 03:39 PM
saber's Avatar
03 E55 k2; Ford GT
let me know when you plan to go
Old May 3, 2005 | 08:10 PM
cte430's Avatar
'07 Porsche 997TT
check your PM
