Which is it 5.5 liters or 5.4?
Old May 25, 2005 | 08:29 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Over the last year of owning my 55 I have read many posts and articles that say the E55 motors are a 5.4 liter and several post that call it a 5.5 liter. Which is it? Are the supercharged motors different than the N/A motors?
Old May 25, 2005 | 08:34 PM
MBE55AMG's Avatar
'03 Yukon XL Denali, '06 Eclipse GS
5.5l
Old May 25, 2005 | 08:40 PM
E55Cent's Avatar
Originally Posted by MBE55AMG
5.5l
That is what I thought, but I see it all the time as 5.4L
Old May 25, 2005 | 08:44 PM
MBE55AMG's Avatar
I notice that too. Fruitcakes.
Old May 25, 2005 | 08:45 PM
dgussin1's Avatar
2016 GLC300 sport
5.439L, so technically it is a 5.4
Old May 25, 2005 | 09:55 PM
korveine's Avatar
2005 E55
Was wondering about that too...
For the 2005 E55, here http://www.mbusa.com/brand/models/E55.jsp it says "AMG-built intercooled supercharged SOHC 5.4L 24-valve V-8 engine."
and if you select Features and Specs -> Specifications ( http://www.mbusa.com/brand/container...pec=0&menu=3_0 ) it says "Engine AMG-built intercooled supercharged 5,439 cc SOHC 24-valve 90° V-8. High-pressure die-cast alloy cylinder block..."
For the 2006 S55, here http://www.mbusa.com/brand/models/S55.jsp it says "AMG-built 5.5L supercharged 24-valve V-8 engine"
and if you select Features and Specs -> Specifications ( http://www.mbusa.com/brand/container...pec=0&menu=3_0 ) it says "Engine AMG-built 5,439-cc supercharged SOHC 24-valve 90° V-8. High-pressure die-cast alloy cylinder block..."
both say 5,439-cc and the technical details of both engines appear to be the same.
so maybe it is just a marketing ploy just like E55 is rated 469HP whereas S55 is rated 493HP.
The 2006 CLS55 is 5.5L but same 5,439-cc and is rated at 469HP.
The 2005 CL55 and 2005 SL55 appear to be rated same as 2006 S55 for the engine.
Anyone know if there's a real difference with these engines?
Old May 25, 2005 | 11:01 PM
houston's Avatar
04 E55
my guess is that they are the exact same engines but it's the restrictions that keep them differently apart.. example would be if the exhaust would restrict where the CL and SL and S would have better flowing or maybe something like the intake. If you have the same engine but restrict air coming in and restrict the air goinig out, i assume it would produce less power in the outcome.. just my 0.2cents..
Old May 26, 2005 | 02:49 AM
dmzz's Avatar
5,439cc = 5.4L
So, your AMG has a 5.4L motor. It's very common for the manufacturers to round up the #s for marketing purpouse.
Old May 26, 2005 | 04:32 AM
houston's Avatar
04 E55
I guess they should call our cars 54's instead of 55's.. E54 .. now that would sound weird.. that's just cuz we're used to 55.. heh
Old May 26, 2005 | 10:12 AM
A-Train's Avatar
ML63
"55" versus a true 5.4L is just a marketing tactic. As long as the specs are accurate, the model designation can be called whatever the mfr wants.
For example, the "600" current Mercedes is 5.5L (5,513 cc). And the Ford Mustang GT/LX "5.0" from a few years back was actually 4.9L in displacement. Makes for better marketing, no question.
Imagine if the Volve XC90 actually had 9 liters under the hood...
- A-Train
Old May 27, 2005 | 07:42 PM
Vadim @ evosport's Avatar
C32 AMG
In Europe, for tax purposes, engines are rounded up. So even if it was 5401cc, they would still call it a 5.5L.
Who says laws of math can not be broken by a bureacrat.
Old May 27, 2005 | 08:00 PM
FloridaE55's Avatar
Something on 4 wheels..
Another one:
4.8 liter 7-series BMW, now called 750i,
previos 4.4 liter called 745i.
BTW, good post I noticed this difference between the CLS55 and the E55, too. My first impression: Cool, they improved the engine - well, just an illusion..
Old May 27, 2005 | 08:49 PM
tommaey's Avatar
2012 C63 Coupe Iridium Silver
Wasn't the BMW E39 540i 4.4L?
That always confused me
Old May 27, 2005 | 10:18 PM
E55Cent's Avatar
Before 97 the 540's were 4.0 liters. I heard the reason BMW kept the 540 instead of going with 544i is because "4's" are bad luck in Asian countries, much like the US and 13. I'm not sure if this is real but just what I was told.
Mario
