For Better Performance: Headers or LSD?
Now - if you CAN'T put the power down with the K1, then it is a different story.
For having fun around town I would say headers and pulley, for track sounds like the LSD might be a good start.
..........which drag radials do you use? Do you have drag radials in all four wheels or just in the rear wheels? what tires sizes. Thanks.
Ted
Your car stock will pass most vettes and porsches. With K2 you will destroy most. Your car will be running 0-60 in under 4s and 1/4 times in the mid 11's.
Enjoy
I run the BF DR's only on the rears with a 275 tire size. I pump the fronts up to about 45 psi. I'm looking for a cool, hopefully MB, 17 inch rim that will fit our cars so I can run the MT SR's which are suppose to be even stickier.
LOL, they seem to be really cool guys. They haven't done any work on my car but they do have some good ideas. I'm workin' on it.
Is this the FINAL mod or are you going to do one then another? Is it going to be 12 months before you can do the next step or 3 months? In the end, I'd probably defer to my tuner's advice and then get everything when you can get it done.
I wish I had done DR's and LSD before I did K2. I did NOT break into the 11's with K2. That did not happen until I had the LSD and the DR's. It's kinda like the criticism of the 600's and the 65's- you can have all the HP in the world but if you can't properly get it to the pavement, then it doesn't matter.
What was your baseline dyno and then the dyno after the K1 install?
So when I take it in.....they will be the ones giving it gas...not us... correct?
Just get worried bout some schmoo hurting my baby......
Thank God for the rev limiter.
