O2 sensors disconnected/CATS removed
I am ready for criticism
Pre cat sensors disconnected
Cats removed
so far little chanage in performance its an E65 brabus what you guys think should happen regarding performance
Cats removed
No mistake on Comp???...
I'd say put O2 sensors back, as you car wouldnt run full power as ECU does not get any information regarding the Air temp and mixture in the exhausts and you car will run in a lean mode...
03 E55 k2; Ford GT
Cats removed
Cats removed
Nothing on the intrument cluster no CEL surprisingly though cats removal made some change O2 sensor removal nothing and if any thing it runs a bit better may be my imagination or the sensors were dead anyway
Sounds strange if O2 sensors are dead the system sound detected it...Speak with MB and see what they tell you ewhat happans if O2 sensors are dead...
On M5 it definately an issue, if sensor goes bad, then system detects it and car runs in FALSeSAFE mod...
Who knows
may be you not getting 100% out of your 65 engine...
Who knows
