evosport Rotors Now In Stock
Old Sep 13, 2005 | 12:30 PM
evomike's Avatar
Premiere Sponsor
The evosport Cross Drilled and Slotted AMG Replacement rotors are now available and in stock. These new multi-piece rotors are a direct bolt on replacement for the OE AMG brake calipers (OE E/CLS/S/CL/SL55 applications).
Not only will the upgraded disc help mitigate brake fade, but reduce unsprung weight by as much as 15lb. per corner up front! And you get to keep the OE look of the calipers w/o going to a more expensive solution that requires replacing them. These discs are more inline with what you find on the 65 AMG cars.
The central “hat” section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron, constructed in the USA and is made to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes high strength alloy steel drive pins and are cadmium plated for long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers.
One more important thing worth mentioning here...the stock discs do NOT have a unique right and left part. This means there will be one side (the right side) where the vanes of the disc are backwards hence working against optimal brake venting. The new discs offer a left and right so that the vanes are pointing the correct direction for venting.
Call now to order. Introductory pricing is $1,999.00 for the set. For more information, click here.
Attached Thumbnails evosport Rotors Now In Stock-es-e55brake-front-rear.jpg   evosport Rotors Now In Stock-dsc06242.jpg   evosport Rotors Now In Stock-dsc06258.jpg
Old Sep 13, 2005 | 12:50 PM
Evolution Marine's Avatar
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Thumbs up Great Product !
Mike - Your new Brake Rotor system looks great and the specs. look great also. Have you found any rattling noise from the disc floating system yet at low speeds with the brakes not engaged? Also, have you tried "Porterfield" Carbon Kevlar pads with these Discs? - Bob
Old Sep 13, 2005 | 01:10 PM
Jon Winter's Avatar
C32 AMG, CLK 320
Great job!!
Old Sep 13, 2005 | 01:12 PM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
we all luv the new rotors you guys came up w/ and if you lowered the price to a more reasonable price point you guys would sell the crap out of them!!!!!!
anyone up for a group buy?
Old Sep 13, 2005 | 01:19 PM
JamE55's Avatar
Out Of Control!
Mike,
Those rotors looks great. Just curious how do they compare vs the Brembo BBK's? Are they the same weight or lighter? And i'm assuming those are 355mm or are they 380mm?
Old Sep 13, 2005 | 01:20 PM
evomike's Avatar
Premiere Sponsor
We have not experienced any chattering with the rotors at low speed, nor have we tried the Porterfield pads yet.
Old Sep 13, 2005 | 01:28 PM
evomike's Avatar
Premiere Sponsor
The rotors are 14.2"/360mm Front and 13.0"/330mm Rears
Old Sep 13, 2005 | 01:43 PM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
What is the life expectancy of these rotors vs. the factory rotors?
Old Sep 13, 2005 | 03:10 PM
Dave OH's Avatar
R170
WOW those are soooo hot! Hopefully cooler too.
Old Sep 13, 2005 | 03:18 PM
evomike's Avatar
Premiere Sponsor
Depending on driving habits, these rotors should be good for 50,000 miles.
Old Sep 13, 2005 | 05:57 PM
e55 baller's Avatar
W221 S65 AMG
<<Not only will the upgraded disc help mitigate brake fade, but reduce unsprung weight by as much as 15lb. per corner up front!
this is awesome. What is the weight savings in the rear? And in total for all 4? Can one purchase the fronts only?
Old Sep 13, 2005 | 06:01 PM
vraa's Avatar
Originally Posted by www.evosport.com
Designed as a direct brake disc replacement for the OE E/CLS/S/CL55 AMG brake discs on all four corners (No modifications are necessary. The disc will bolt directly to the car and work with OE AMG brake calipers). Not only will the upgraded multi-piece "floating" discs help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them. Available drilled or slotted or slotted.
Copied from Evosport's site.
Old Sep 13, 2005 | 10:23 PM
e55 baller's Avatar
W221 S65 AMG
nice...34lbs is like 70lbs sprung weight reduction...add a light battery, lighter rims, and a CF hood and you have taken the fat 4200lb sled down to roughly 4075-4100lbs or so...an effective increase of about ~10-15hp.
Old Sep 14, 2005 | 11:13 AM
evomike's Avatar
Premiere Sponsor
These rotors are sold as a set of 4 only.
Old Sep 14, 2005 | 11:56 AM
vrus's Avatar
2003 E55 AMG
Hey Mike.. Don't forget about me.
Old Sep 14, 2005 | 12:06 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
What about for W210 55's??
Old Sep 14, 2005 | 12:27 PM
evomike's Avatar
Premiere Sponsor
The rotors are not available for the w210.
Old Sep 14, 2005 | 12:43 PM
JamE55's Avatar
Out Of Control!
Brad,
You should consider Brembo BBK.
Old Sep 14, 2005 | 06:27 PM
Fast55's Avatar
Don't want the Brembo's. Either drilled/slotted rotors for the stock calipers, or somehow fit W211 brakes for the "AMG" look.
Old Sep 14, 2005 | 09:36 PM
gmdebruyn's Avatar
2005 E55, 2010 ML350
as compared to how many miles with the OEM ones? anyone know?
Old Sep 15, 2005 | 03:20 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Can anyone testify on some real life results?
Old Sep 15, 2005 | 04:09 PM
JamE55's Avatar
Out Of Control!
Vic55 has them in his car and from what i've heard it works great!
Old Sep 15, 2005 | 05:33 PM
MBH's Avatar
MBH
2005 E55 Delivered 01/07/05
DID I just read that right $2,000 for brake rotors?????
Old Sep 15, 2005 | 05:37 PM
vraa's Avatar
How much is better handling worth to you? Especially on a product that has extensive R&D, a fantastic support team, and they look wicked tight as well?
Old Sep 15, 2005 | 06:09 PM
vrus's Avatar
2003 E55 AMG
$500 for each rotor with floating aluminum hats, directional vanes, zinc coated, cross drilled is a fair price.
MB wants $1000 each I believe..
