Overheated brakes
They insisted we run teh track with ESP on, so the continual ESP corrections and intrusions that happen when you start to slide has a major influence on retaining heat during the traditional non braking segments of the course, as brakes are actually applied when you are accelerating / sliding / drifting etc. And then not to mention the violent braking at the end of each straight trying to slow down 4300lbs of fast moving machinery to make the turn.
Most, if not all calipers were turning various shades of gold, several of the front rotors were showing small hairline cracks at the cross drilled holes, and when running hot laps at the end of the day, you could feel that on some cars the brake rotors were pretty much done - excessive vibrations from warping and glazing.
I know Eagleye (on this board) experienced a complete failure and ended up in the kity litter, but I cerainly didint hear of any one else. I did both days at Homestead and one day at Road America.
The instructors and the AMG boys were totally unfazed about the warning lights, the calipers or the rotors, although Jeff Andretti concurred on one of our last runs that the brakes were toast!
I also left me ESP on when I did the track day, I wasn't concerned about being a little slower, I wanted the car to look the same at the end of the day!
My rotors already had surface cracks when I went to the track, the track made it worse, they were pretty colorful, but they still stopped great and were not warped or anything.
Good to know you can still keep going with the warning on, I ended up cutting a couple of runs short because I wasn't sure. I mentioned to the instructor I was riding with that more than likely most cars there would be experiencing the same problem but ours is the only one that lets us know.
Anyway, you guys should take your car to the track sometime. Its a lot more rewarding than just going a 1/4 mile at a time.
