Switched from Castrol Syntec to Mobil 1- made a difference!!
Old Feb 10, 2006 | 01:30 AM
paulunm's Avatar
2000 G500
For some reason the dealer where my '00 E55 was serviced last put Syntec motor oil in- I just changed the oil myself and went with M1 0W 40. I swear the car has more power, and idles more smoothly. Maybe I'm imagining things, but I have always used M1- and I thought I would share.
Old Feb 10, 2006 | 01:35 AM
MB Fanatic's Avatar
4 wheels
What bloody dealer is this?
As far as I am concerned, MBUSA has always told its dealer to use nothing but Mobil 1.
chem0's Avatar
2004 E55 AMG
ummm.. if im wrong someone correct me
but isnt there a little sticker at the front of the engine bay saying
"Mercedes Benz and ///AMG recommends Mobil[1]"
or something along the lines of that?
then why would you dealer put anythin else in
Old Feb 10, 2006 | 01:37 AM
idrive's Avatar
2017 SL63
I'm a believer in Mobil 1, as is Mercedes...
Seems strange a MB dealer would use anything else
BMW is using castrol. couldn't be to bad
x15jq's Avatar
i donno my dealer used to put in quaker state syntec, its cheaper and no mbusa doenst regulate the dealers close enough to monitor each and every oil change.
Old Feb 10, 2006 | 01:38 AM
Evolution Marine's Avatar
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Thumbs up Your Not Dreaming!
Using 0-W40 Mobil 1 will allow more power to the rear wheels because it is easier for the oil pump (less HP required to run the oil pump) to pump the oil thru the Motor. This is because the oil has less viscosity and is a superior lubricating film. - Bob
Old Feb 10, 2006 | 10:05 AM
jangy's Avatar
2015 S212
Benzes MUST use Mobil 1.
Hehe. Sometimes cars run better after a service... IF THEY NEEDED IT SO BAD!! How often do you change your oil and how harsh are you on it? Maybe you should just change it more often. It's not a good sign when you see a difference (especially smoother idle) after an oil change. It is a tell tale sign that the oil had broken down.
Old Feb 11, 2006 | 08:36 PM
paulunm's Avatar
2000 G500
I drive it pretty hard, I will be changing the oil every 3k miles. Dealer was in Tacoma, WA.
Old Feb 11, 2006 | 09:46 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
On other cars, I have noticed a dramatic change from changing out a dino oil with 20 easy miles to a synthetic, and a noticeable change from Mobil 1 to Redline.
