PDC Parking Distance Control
Old Mar 7, 2006 | 09:17 AM
leepy55's Avatar
2008 S63
I really regret not getting PDC and the pano roof. I know a retroactive fit of the pano is IMPOSSIBLE ... but have any of you considered/looked into/done the retro fit of PDC? What's involved in the process? Is it a DIY job?
I figure a new rear bumper and some wiring to the interior are all that's necessary? Any input is greatly appreciated!!! Peter
Old Mar 7, 2006 | 10:06 AM
BigSis's Avatar
Former Vendor of MBWorld
Nothing MB related (sorry)
Parktronic can definitely be retrofitted, and since you have a W211 E-class, you only need to swap the bumper STRIPS for ones that have PTS holes... instead of swapping the entire bumpers.
I wouldn't recommend to do this yourself, as retrofitting parktronic requires removing part of the interior in order to run the wiring.
Depending on where you live, Steve (MBenzNL) can do it for you... Check out this link:
https://mbworld.org/forums/showthrea...ght=parktronic
greetingz,
BigSis
Old Mar 7, 2006 | 10:32 AM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
how do you mount the displays? drill holes in the dash and headliner?
This is why whenever people ask about options I always say get all of them.
Old Mar 7, 2006 | 11:16 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Steve did The Wifes W211 and She LOVES lt!...The Job Is Not recommended for the DIY..Its a Lot of Work to Install the Wire harness...runs from the front to the rear...also the dash must be removed to install the front display...
Old Mar 7, 2006 | 01:06 PM
MBenzNL's Avatar
some slow@$$diesels
we already did quite a lot of (W211/S211) parktronic retrofits...retrofitting parktronic in a 211 sedan takes 1 long day and is definitely not a DIY...once we're finished with the parktronic install it looks and IS exact the same as when installed from factory...it is not as cheap as when it would have been ordered from factory though - please be aware of that!
greetingz,
Old Mar 7, 2006 | 02:28 PM
Fleebee's Avatar
S211 AMG
can you do the wagon?
Old Mar 7, 2006 | 02:30 PM
BigSis's Avatar
S211 = 211 E-class station = wagon... so yes, MBenzNL can retrofit PTS in a W211 wagon as well.
greetingz,
BigSis
Old Mar 7, 2006 | 02:54 PM
Fleebee's Avatar
S211 AMG
Thanks for the clarification. What's the "w" represent in w211
Old Mar 8, 2006 | 03:44 AM
MBenzNL's Avatar
some slow@$$diesels
the W stands for sedan...S stands for wagon...you can ask jeffreyy on this forum how his 211 wagon parkronic setup turned out (as that is the last one we did - 2 weeks back on hawaii) - here is a link to one of his posts .
greetingz,
