RennTech Warranty
So does anyone know if our cars can be modfied, but still remain under warranty? I called the contact person on the website, but he wasn't there so i left him a message, in the meantime i'm asking here in case someone can give me an answer.
thx
http://www.renntechmercedes.com/PDF/Warranty.pdf
How do you expect Mercedes USA to warranty parts they don't sell or make?
I posted a thread about it too:
https://mbworld.org/forums/showthrea...ified+warranty
Loren
I just ran into a problem with this. I was looking a at a 14' C63 with 25k miles on it that had a RennTech stage 1. The car is being sold by a dealer and they informed me that they would not certify it and that because it had "performance mods" done to it that voided the factory warranty. This is a hard pill to swallow on a $43,000 car.
I wonder if you purchased an aftermarket warranty if it would cover it ?
The link below is a good article an attorney wrote about how modifying your car voids the vehicle warranty:
http://www.newyorklemonlawlawyer.com...modifications/
Of course there is the Magnuson Moss Warranty Act which states that a manufacturer cannot void a warranty if the modification did not cause the failure.
https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act
But a tune increases horsepower and torque and therefore puts greater stress on the engine, transimission and driveline, and even accessories if maximum rpm is increased. So if anything affected by the increased hp / torq from the tune fails, the manufacturer can and will deny warranty coverage.
By the way the M278 Mercedes Biturbo uses the 7G tronic transmission which has a maximum torque capacity of 700 Nm or 516 lb ft. This is not by coincidence the maximum torque output of the M278 engine in an S Class.
The transmission's first gear has a maximum torque input from the engine of 516 lb ft. Because of its high torque multiplication from gearing, the first gear clutches would slip if the engine input torque were higher. Just a design limit of the transmission.
Other gears can handle more engine input torque because of lower torque multiplication from lower gear ratio.
Therefore tuners cannot exceed the maximum torque the transmission can handle in first gear (516 lb ft) and thus a great deal of acceleration performance gain is left off the table as WOT in first gear takes these Mercedes to approx 40 mph.
(Dont know if tuners are maximizing torque curve in 1st gear up to 516 lb ft, which would increase performance times in 1st gear).
So 0 to 60 times are not really all they can be with claimed 540 hp and 700 lb ft Renntech (and similarly Kleeman) tunes. And of course quarter mile times suffer also because of inability to maximize engine torque in 1st gear.
That is why some owners may be disappointed with their before and after tune acceleration performance increases.
http://www.europeantransmissions.com...edes-trani.PDF
