Lightweight Battery Replacement?
Old May 10, 2006 | 10:06 AM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
I know this has been discussed before, but I couldn't find anything concrete on it. What is the best lightweight battery replacement for our w211?
Old May 10, 2006 | 10:32 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I think heavy battery better for traction than the advantage you will get by saving weight ... ?
Old May 10, 2006 | 11:25 AM
BenzoBoi's Avatar
Super Moderator
W221
have you considered optima? I know they are very lightweight but I don't know if one is available for our cars...just throwing out the idea???
Old May 10, 2006 | 11:36 AM
Kens-E55's Avatar
2004 E55
Rgds Steve.
In that case-running to NAPA and buying my 250lb. Commercial battery
Just teas'n
Old May 10, 2006 | 12:14 PM
stevebez's Avatar
Heheheh yep ... anyone thought of adding ballast to trunk / rear to see if it helps traction at all ... mbe 1 offensive guard and 1 offensive tackle should do it !!!!!!
Reckon a stock-er will run 13-14 with that line up...!
Old May 10, 2006 | 12:55 PM
L8Apex's Avatar
05E55
I used a Optima motorcycle battery in my Porsche. It weighed about 5 pounds.
Old May 10, 2006 | 01:14 PM
GTA23109a's Avatar
04 E55
There's a line of gel-cell batteries called "Odessey" as well that I've seen a lot of guys at the racetrack use. They're a little larger than a motorcycle battery, but still much lighter/smaller than a standard Optima or car battery.
Old May 10, 2006 | 01:40 PM
dragonAMG's Avatar
I found the thread: https://mbworld.org/forums/showthrea...hlight=Odyssey
Here is the link to the battery: http://www.batterymart.com/battery.mv?p=ODY-PC925MJT
Thanks.
Old May 10, 2006 | 03:52 PM
e55 baller's Avatar
W221 S65 AMG
I got mine at the battery mart...drove to the shop from Leesburg, VA was gonna get the 14 lb batter but got the 25 lb one...still saved 28 lbs over stock. No problems cranking it. The 14lb one died once in my S4 hence the move up to the 25lber.
Hope this helps. On the scale my car weighed a slim 3995 lbs
Old May 10, 2006 | 04:48 PM
dragonAMG's Avatar
Good deal... I just ordered mine. I just read your sig. Do you have an updated 1/4 time with the new mods and weight reduction?
Also, I noticed that you discussed the possiblity of getting the EVOsport rotors in another thread. I just ordered my set. I'm interested in seeing how they perform. From what I've gathered the savings of 34lbs. in unsprung weight which is equivalent to 120 load weight lbs. Essentially that translates into 10-12 rwhp. We'll see.
Old May 10, 2006 | 05:11 PM
Rock's Avatar
Administrator
Drives Slowly
Every time I think I'm about done doing crap to my car........I see a new thread on something I missed.
Old May 10, 2006 | 05:54 PM
dragonAMG's Avatar
BAWHAHAHA... I know what you mean. Having an E55 AMG is like being addicted to crack.... always fiening for more (mods that is).
Old May 10, 2006 | 06:07 PM
GTA23109a's Avatar
04 E55
Originally Posted by dragonAMG
That's the brand, but the one's I've seen are about half as thick. Probably cutting it close for our cars though. I see them a lot in NASA Time-Trial classes where guys want to cut the weight, but take a points penalty for relocating the battery. Seems to be a pretty popular and reliable mod.
