Trap Speed - Can a bad launch impact it?
if you want to get a good idea of your trap speeds, leave ESP on, and just jump on it slowly off the line for .5 sec, then hammer it....
most of the time the traps will be pretty consistant, good launch or bad...
BUT, if you have to keep letting off the gas down the track, then it will bring down the traps.....
When you get a sec....let's take a look.
You'd be surprised how great that "quickly but smoothly without mashing" launch technique works. Fastest stock Benz in the US swears by it.
60 ft. .............1.8
1/4 mile............12.072
MPH.................115.8MPH
Recently got the Kleemann I/C Pump which I think helped tremendously. Had to drive 45 minutes to the track and ran it immendiately when I got there. Had a chance to run it 6x. Experimented with ESP off, shifting manually, etc. This was my last run of the day. Car never had a chance to cool off. Literally had no more than 5 minutes cooling period between runs.. Trying to break into 11s. This was frustrating, but I think with a cooler engine and a better launch I can get there. FYI, this was on PS2s.
Your 60' and et are Very Respectable! To have a 12.0+ trap et, you should be knocking on the door of 120mph's trap speed. Based on your times, it would appear you do have a cooling issue .... as the motor is building boost thru the 1/4, the intake charge is probably getting to hot and the timing is being retarded...hence your low 115mph trap speed............
GET the cooling upgrade!!:zoom:
the ET and MPH don't line up with your mods though.... you should be pulling 120+ traps easily with your level of mods....
questions:
what track was it at? and what was the outside temps?
have you had the car dyno'd?
have you had the ECU service campaign done and the computer re-flashed by RENNtech?
questions:
So do you think that my not achieving 120s has nothing to do with my launch?
Trap Speed = Much power your making
60ft = how good your traction is
If I can get nearly 116 bone stock, I'm surprised so many modded cars have only marginally faster traps.
Think about this:
The car that gets to 60 ft the quickest is accelerating the fastest.
A car like the E55 will easily overpower the tires on a hard launch and give a poor 60 ft time. Now, if that same E55 is down on power, the tires have a better chance to grip and will produce a quicker 60 ft time. BUT, that same car will have a slower trap speed because it's down on power.
60 ft times and trap speeds are not highly correlated.
Think about this:
Ted
Ted
https://mbworld.org/forums/w211-amg/141238-finally-tracked-car.html
The car's 60ft will not change more than 1 to 2 mph of trap speed from my experience. Contrary to popular belief your car can 60ft better and still trap higher mph.
Ted
http://www.jumptronix.com/TeamJumper/Time_Slips.htm
I Googled 60 ft time trap speed to find this URL - it was the 7th listing on the 1st page.
Ted
