ITG Profilter Air Filters
Rating: Thread Rating: 7 votes, 5.00 average.
Old 06-01-2006, 03:11 PM
vrus's Avatar
2003 E55 AMG
I am in the process of ordering 2 of these to try out on the E55.. I used something similar to this on some of my previous cars and it worked great.. They are supposed to be a great product with much higher flow and better filtration qualities than the standard cotton filters (K&N, Green, BMC, etc)..
If anyone else is interested in them, the Part # you want is WB-379
Here is a little blurb on the product:
http://www.itgairfilters.com/content...tion=profilter
Of course, like everything else, I'll let you guys know what I think once I install and try them out.
Old 06-01-2006, 03:49 PM
SS3E55's Avatar
E55
filter / filters / and more filters
your post came just in time. I was just about to order the greens - Vrus what is your opinion...green K&N or these ?? Have you measured differences on dyno?
Or does the breathing change actually show up in use as a different feel at all (suspect not as most advertise around 3-5 HP gain).
Curious...thanks
OH BTW the selector says E55 is WB-537(x2) and that the WB-379 is S class...are you sure on the number?
Old 06-01-2006, 04:30 PM
Former Vendor of MBWorld
BlackC230Coupe's Avatar
Fast Cars!
I remember i use to have ITG on my old car. Then i remember seeing people Dyno their C32's with ITG and lost HP. Never a good thing.
Old 06-01-2006, 04:42 PM
vrus's Avatar
2003 E55 AMG
Not sure which is better.. I am ordering a set to try them out and see how it reacts on the E55.. I can let you know once I have them on the car. I am using the BMC Race filters right now and have been very happy with them. But, for the price of 2 filters, it isnt alot of money to experiment with.
The online application chart is wrong.
WB-537 is 334mmx188mm
WB-379 is 350mmx133mm
WB-379 is what we need.
Curious...thanks
I hear you... I hear good and bad about alot of things but I like to try things out for myself sometimes and just see how it goes. Claims of gains or losses usually dont matter much to me because unless I know exactly how the tests were done, sometimes the feedback you receive is not accurate.
I do appreciate your input though.. Thanks.
Old 06-01-2006, 05:57 PM
Griffin337's Avatar
E55
Let me know if you want to make a deal on the used BMC's!!
Old 06-01-2006, 07:14 PM
L8Apex's Avatar
05E55
Thanks for the part #! Just picked mine up today!! They will be in the car tomorrow!!
You must have read my mind: https://mbworld.org/forums/showpost....2&postcount=38
Old 06-01-2006, 08:23 PM
vrus's Avatar
2003 E55 AMG
No problem!! That's what the forum is all about; sharing information.
Turns out the guys I talked to are no longer distributing the product so I was going to order direct from UK... Did you get yours local in the USA somewhere?
If you could pass along the info I would rather buy from the US than ship from UK. Thanks!!
Old 06-06-2006, 10:13 AM
E55 RUSS's Avatar
E55K
OK..did anyone actually made any power with Greens ???
Old 06-06-2006, 10:47 PM
Jrocket's Avatar
E55
Im trying to find this info out as well.
Old 06-06-2006, 11:37 PM
vrus's Avatar
2003 E55 AMG
Mine are on the way.. I *WILL* be doing before/after dyno pull with these filters to see if there is any improvement.
I have to get on the dyno to check current powerlevel so I will wait until these arrive and then do 2 pulls to see if there is any noticeable gains.
Old 06-07-2006, 12:36 AM
L8Apex's Avatar
05E55
Vrus,
We tested these (ITG) filters on our racecar E36 M3 (euro 3.2 normally asp). We found that the K&N filters made a tad more hp & tq + 1 or 2 when brand new over the ITG filter. After several races on both filters the ITG filter barely dropped in hp & tq. On the other hand the K&N made less power -3 hp at peak rpm. After a wash and re-oil on the K&N it was still down approx 2hp to the dirty ITG. We then cleaned the ITG and made the exact same power when it was new.
I’m sure several conclusions could be made. Our thoughts were:
1. We might have used too much oil on the K&N after cleaning clogging the pores. Resulting in lower power than new.
2. We did not oil the ITG enough
3. The dyno was throwing off wrong numbers
In either case, the ITG was always consistent and easy to maintain. We inspected the intake after running both filters and noticed no increase in dust or oil residue, it was always clean. Again this was on a normally aspirated motor. The 55 might have a differnt outcome.
Just my 2 cents. Good luck!
I look forward to seeing your results!
Old 06-07-2006, 03:01 AM
E55 RUSS's Avatar
E55K
Vrus...what was your experiences with Greens and make sure your post your results with ITG...will be waiting...
Old 06-23-2006, 01:39 PM
Renault78law's Avatar
2003 C32
anyone know the part number for a C32?
did you order from the UK? is there a source in the USA?
Old 06-23-2006, 02:55 PM
BIG LUV's Avatar
'06 E55 Black/Charcoal
I did a before and after with the green filters and gained 1whp. Look for the thread.........Dynoed my E55 today
Old 06-26-2006, 10:35 AM
E55 RUSS's Avatar
E55K
Extra 1 WHP is good
Old 06-26-2006, 11:12 AM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Any updates VRUS?
Old 06-26-2006, 05:18 PM
vrus's Avatar
2003 E55 AMG
I've had the filters for a while but havent installed them yet because I want to do a before/after dyno..
Been a little pre-occupied with trying to finish off this 80mm TB project though, so the filters are still sitting waiting to be installed. They'll have to wait until I am ready to do another baseline dyno pull.
Old 06-27-2006, 04:30 AM
E55 RUSS's Avatar
E55K
Waiting impatianetly for your results...
Old 06-27-2006, 06:23 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Old 07-06-2006, 03:33 PM
vrus's Avatar
2003 E55 AMG
I went onto the dyno today to do some more baselines for my car..
The car was sitting for a while before I got onto the dyno so the engine was stone cold for the first run. I actually had to bring it up to operating temp while on the rollers.
I ran the car with my BMC filters first, then swapped out for the ITG profilters.. It took 15min for me to swap the air filters..
Bottom line is that the ITG filters showed -2rwhp and -2rwtq on the second pull.. Now, usually the second pulls are at least 10rwhp - 20rwhp (if not more) lower because of the heat soaking on a stone cold car.
I personally think the ITG filters are flowing better because it feels a bit more responsive while driving, but, because the car went on really cold and then ran hot for the second pull it's hard to make proper conclusions.
I am going to leave them in the car for a while and do some more pulls when I get some time.
Old 07-06-2006, 03:49 PM
DFW01E55's Avatar
'14 ML BT
Thanks Victor, your informative posts are much appreciated.
Mike
Old 07-06-2006, 08:42 PM
vrus's Avatar
2003 E55 AMG
You're welcome. I try to do my part as best I can...
Mike
Old 07-07-2006, 08:48 AM
E55 RUSS's Avatar
E55K
So you reccomend not to gwet them ???
and get Green or BMC instead ???
Old 07-11-2006, 10:10 AM
vrus's Avatar
2003 E55 AMG
Stay away from these ITG filters until I've had a chance to sort out a few things...
They definitely provide more airflow to the motor than the BMC filters I had, BUT, I noticed that the rubber edges that run along the perimeter are a few mm shorter than the other filters.. They seem to move around a bit too much when you insert them and that bothers me a bit. I wouldnt want them to collapse in the airbox and let all kinds of crap through.
I need to verify whether I have an anomaly or whether this is the norm for these filters.. I sent an email to ITG and am waiting a response.
If you need filters right away, I would say grab the BMC. I havent tried the Green filters, so I cant comment on those.
Old 07-11-2006, 11:43 AM
L8Apex's Avatar
05E55
I did not notice any big movement on mine. It could be the smaller boxes on the my 05. Who knows?
Do you have the wrong part #WB-539 or 7 (S not E class)?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: ITG Profilter Air Filters
