How To Remove?
Thank you!
https://mbworld.org/forums/w211-amg/147791-v1-install.html
try it out or just take it in an complain.... the dealer will fix it for you. : )
https://mbworld.org/forums/showthrea...84#post1629884
if yours is the actual tach and between the clear plastic you see thru to see the guage, thats now what i removed.
. If anyone here knows for sure if the 211's are one or two pieces and exactly how to do it I would appreciate a quick reply.
Hope this is quick enough....
That's the piece I was talking about, it seems to be rattling against the clear plastic cluster cover. Thanks for the pic and info
If you have something lose, I'd check each post that the clips connect to in the instrument cluster and make sure they are ok... they consist of two posts each and can be bent a little... hopefully one isn't just broken, and thus not secure...
good luck,
Loren
Attachment 83270
Attachment 83271
LOL Nice Photo shoot LOL...
good luck,
Loren
BTW you look a bit like Bruce Willis when he had hair...
So far, the stuff looks nice... a little darker than the OEM stuff though...
Loren
I tried to remove mine but it seems either I'm not doing it right or the clips are really tight. Where exactly did you put the flat head as I don't want to mar the dash.
