E55 cooling project
I was just about to say the same thing...
The front mount is not the intercooler. From my knowledge, the intercooler is right below the supercharger...so unless you found a way to go through the intercooler underneath the blower, I think this topic has already been talked about???
1 fitting a fatter IC under the S/C (Assuming there is sufficient space etc to allow this)
or
2 A bigger heat exchanger...?
well anyway am going to spray the liquid CO2 on the heat exchanger and ill hit the dyno asap and will let you guys know about the resaults..... finger crossed.
This is the most efficient design for "Boosting" applications.
You have quicker throttle responses(instantaneous)-'cause you're not losing pressure to long intake pipes!
The trick is to get the coolant coming from the heat exchanger to be as "Cold" as possible...that will allow the IC to also be effective at cooling the pressurized air.
I have actually thought of designing an exchange cooler that has auxilliary lines and small pump (closed system) where we could place "ICE and run ice water" that would be effective for say hrs. at a time???
Try what your doing - I'm interested to see the results.
or
But if I had to guess, I would go with #2.
With #1, the intake charge is exposed to more surface cooling area, which should provide a little additional cooling. But each time the coolant makes a pass through the system, it brings back a little more heat for the heat exchanger to process. If the size of the heat exchanger is just big enough the cool the original IC, the coolant begins to heat up. Eventually, it will reach an equalibrium temperature, but that temperature might be a little higher than if the IC were smaller. Bigger cooling area with a little warmer coolant could equal no difference. Or it could be worse.
With #2, the coolant extracts the same amount of heat in the IC, but with a bigger heat exchanger, it should be cooled to a lower temperature. So lower-temperature coolant is circulating, which will provide for a lower intake charge temperature.
With both options there's additional mass to absorb heat due the increased amount of coolant - both benefit.
Of course, this is just my opinion and I could be wrong.
I know that this topic has been discussed to death so forgive me in avance if this has been talked about. As I understand, the water that runs thru the heat exchanger is the same water that runs thru the radiator, so it is safe to assume that it will not be colder than 180 to 200F most of the time. This will cool the intake charge somewhat, but not more than to the temperature of the water. I have not looked at the specifics (I'm sure someone has), but I believe that the most basic thing to do, would be to close the system so that the water in the intercooler does not mix with the water in the engine. I know some of the tuning companies provide their systems with extra heat exchangers and pumps, but I wonder if anyone has tried to create an independent system using our factory heat exchanger and seen results. This would probably be the "best bang for the buck" solution. As I said before, I don't know if this would be possible, but maybe it is
Best Regards
Victor
The coolant @ the thermostat maybe 190+, but the coolant (cooled side)coming out of the radiator is more like 110-130. If it is then routed to the Heat exchanger(any help here on flow direction is appreciated) it will be cooled even more.
Hence the coolant (exiting the heat exchanger)going to the I/cooler I would speculate to be in the 90-110degree range. The real trick here is to get the coolant even "colder"...especially under extreme loads.
Still interested in this cooling project.
The track and Dyno and occasional "tear'n"
up the streets is where this would do wonders.
