If you lower a car just a tad with washers or stardiag, does it change the alignment?
Every professional I have ever known, however, and I myself, always have a four-wheel alignment done after any suspension mod as a matter of course.
It is just a good thing to do -- and is definately less expensive than having to prematurely replace tires...or worse.
If you lower your car the next thing to do is to have a four-wheel alignment done.
Some place of business has this machine or piece of equipment near where you live.
That's where I would go if I were you....
If you want to see what is happening to your suspension, raise it to the max, get out of the car and get somebody else to lower it to Sport 1.
You will see your front (and rear) wheels "fold" into the wheel arches, increasing the negative camber from -0.5 deg raised to -1.75 deg Sport 1.
If you lower it by a further 0.6-0.8" with washers or Star, you will go to -2.25-2.5 deg. Live with it.
if thats the case, no need to get an alignment after lowering with washers or star, correct? if thats also the case, the car will prob handle better as it sits a little lower, (and as it eats tires a little more)
Too much camber (more than negative 7 or 8 degrees or something) will probably damage the suspension. Don't worry though, you can only get that amount of camber if your suspension is broken to begin with, or you want your Benz to be literally on the ground.
Increasing the camber more negative from vertical can have several negative effects. As has been noted, inside tire wear will occur. Steering can become a little unstable on rain-grooved surfaces. On bumpy roads, the car can jump a little sideways if the tire on one side loses contact. Panic stop distances will increase since the straight-ahead tire contact patch is reduced. Now for the worst effect - if the rear tire camber is increased, you will lose traction for 1/4-mile blasts.
