****80mm TB Install Update***
Sorry to report guys - Chris @C2 started the car up yesterday (after driving it the day before w/80mm TB installed) and got a "CE Light"
so he has to investigate a little today before it gets put on the Dyno. I'm hoping/sure
it's only something minor w/TB and Thermostat now installed, 'cause had no
issues what-so-ever with the K2.
Will keep everyone posted.
Please please keep us posted so many of us can inform our installers as many of our cars are ripped apart as I speak....er ehhh, type.
Let us know just as soon as you get some answers, pretty pleeeaasseeee.
Thanks man.
A couple of things:
1) Check the TB screws and make sure they are tightened all the way down and the crush washer actually got "crushed". If it isnt snugged down air will leak in from the sides and throw a CEL. (The welder may have allowed some weld to get through the cracks and up and into the holes for the screws blocking the path of the screw).
2) Make sure the PCV hose (The one I supplied) that runs from the bottom of the TB to the T-connection is on properly and hasnt fallen off the bottom of the TB. Also, check the T that it connects into. The hose that comes off the T and went up to the stock TB is a very small diameter hose. The intent was for the new hose that I supplied to slip OVER the existing hose and be fastened onto the T. Make sure that when it was fastened the stock hose wasnt pinched closed.
3) It could be a "Coolant Too Cold" code that you are getting with the 160TB.. Highly unlikely, but, possible.
I think Chris will need to hookup Star diagnostic to the car and read out the codes. That will make diagnosis much easier.
Good luck and tell Chris to call me if he needs any help.
The harness that goes from the ECU to the TB & from the ECU to the BYPASS VALVE are EXACTLY the same (6pin connectors & wire colours) except for a small BLUE DOT on the outter black casing of the harness..
If the 2 harnesses were reversed it might cause some erratic driving and fault codes.. Ask Chris to double check and make sure those 2 harnesses were not reversed.
Also, with the car parked, the Y-pipe removed, and the air boxes removed, start up the car, rev it while watching the TB.. Does the throttle plate move in accordance with pedal input? Does it rev normally?
Thanks Victor - I'm passing along as you give it to me - much appreciated!
Talked to Chris mid-day. He said the error code was a MAP sensor error code.
He was going to go thru the entire re-inspection of hoses and wiring to see if something was "missed". Hope to hear something tonight or first thing in the morning.
How is everything going? Was Chris able to diagnose where the MAP sensor code was coming from? If he is still stuck please post the codes he is getting and I'll see if I can help.
All is good!! Chris went thru the whole install again, reset teh battery, did a few other checks and POOF.......It's running "insanely fast"
as he says!!No CEL's and all is smooth. Will be on the dyno first of next week and then I'll hope to pick it up mid next week. Thanks Victor for all your input and help on this!!
So, he likes the power does he?
Anyone that has pullies & ECU should be buying an 80mm TB to put on their car.. It is a big difference in the way the car behaves overall.. I'm sure you'll come to that same conclusion once you get some seat time behind it.Take care Ken and enjoy the *new* car..
Just out of curiousity VRUS, this is basically the same kit that Kleemann sells right? Same specs? Same HP?
I'll let the others who have a kit speak up on their own.. BenzGal was the first, Ken was the second, Pasya is being installed right now, JakPro1 (Jim) is almost done..
I stopped saying it and figured others who had it installed would be able to confirm my feelings..
VRP ....................... Kleemann
AMG TB ....................... V12TT TB
80mm Y-pipe ....................... silicon hose to adapt stock Y-pipe to new TB
$2,500 USD ....................... $3,000 USD
Everything else is pretty much the same but different approach.. Both kits have a plate made to adapt TB to inlet.. I dont know what the kleemann inlet looks like but mine is ported to 80mm opening and insides are ported and smoothed also.
I haven't been able to put a V12TT TB in my hands to be able to give a Pros/Cons of using one TB over the other, so I cant guide you in that respect.
Oh Yeah... one more thing... I wont mention names, but, I heard back from someone who bought my kit, and , his installer said something like "This kit is better than the Renntech kit.." .. LOL.. THAT MADE MY DAY!!!!
That's the God's honest truth!
Service advisor asked Ken (SLR Mechanic/Installer) after he got out after test drive, "So how was it?"
He said Ken just walked away chuckling under his breath and shaking his head.
Oh, this is gonna be good!!!
Is the 80mm y-pipe the same as the SL snorkle mod?
Looks like I'm going to be your next kit
Make sure you run right back to your computer and let me know what you think.. I'm dying over here.....
BenzGal, Jim & Ken should all have dynos around the same time.. We'll get a good indication of what it can do because all 3 have different levels of mods on their cars.
