Winter's coming...But, the Heater problem!!!
Old Oct 12, 2006 | 09:27 PM
AMG Rider's Avatar
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
The temperature here in Indiana dropped all of sudden to about
37..So 2 days ago, i decided to turn on the heater and the cold air (a/c) came out
when i set it to 80 (AC off n everything)
Is this something serious?? This happened once long time ago...
Old Oct 12, 2006 | 11:47 PM
D-5's Avatar
D-5
2003 E55
had the same problem since the day we picked up the car in 2003. Instead of warm air, it blows out cold air when its snowing outside. Although I mentioned this problem to my dealer twice, they didn't know where to look.
Old Oct 13, 2006 | 07:28 PM
02S430's Avatar
W220 M113K
interesting noticed it too but then the car was boiling all of a sudden werid
Old Oct 13, 2006 | 09:48 PM
dsc's Avatar
dsc
2004 E55
This may sound trivial but the center dash vents have a rotor dial to switch from cold (blue stripes) to hot (no stripes). Could this be your problem?
Old Oct 13, 2006 | 10:44 PM
schwarz's Avatar
124, 140, 211, 220, 221, 996
yep, you have to turn that dial to hot in order for the a/c to be blowing warm air. if you leave it in cold, the a/c would just still blow cold air into the cabin.
Old Oct 15, 2006 | 12:56 PM
D-5's Avatar
D-5
2003 E55
I've tired almost everything, the dail, ac on/off, turning the temp all the way up, auto climate control to manual, even the outside temp sensor was replaced (was showing 33c when the actual temp was 16c) The ony temporarily fix to this problem I found was to shut off the engine and then restart. (works 70% of the time)
Old Oct 15, 2006 | 04:43 PM
AMG Rider's Avatar
same here...i tried everythingand still doesnt work..
But yesterday heater was working for about an hour then
the cold air came out later on.....hmmm
Old Oct 15, 2006 | 05:38 PM
m3tonyh@verizon's Avatar
'03 E55
MB has an updated heater valve- There is a bulletin about this, they should know about it if not tell them
tony
