Larger IC heat exchanger!!
Old 11-29-2006, 10:06 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
B U M P !!
Old 11-29-2006, 08:16 PM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
I'm surprised this thread hasnt been more active since this looks like a cost effective alternative to the expensive cooling kits.
Old 12-04-2006, 07:00 AM
stevebez's Avatar
Old 12-04-2006, 09:38 AM
blackbenzz's Avatar
haters crazy
I finally installed the AFCO pro series heat exchanger on my Kleemann CLK55 and the temp of the s/c stays warm and never gets hot! I can run it hard, pull over, then just lay my hand on the s/c. Only problem is the heat exchanger is HUGE and the inlet/outlet point towards the back of the car so I couldn't center it properly. It was also too big to put the bumper back on so I had to cut alot of the bumper out I need to find one that will fit behind the bumper because the current setup looks ghetto and ricer. But it does serve a purpose.
Old 12-04-2006, 09:39 AM
E.fifty.5's Avatar
2003-E55
sorry...
just too busy...
I don’t have any pictures but, is really cost me US$550 remember labor is cheaper from this part of the world .it is only the exchanger that I changed, had some problems with the warning to add more coolant even though there are no leaks anywhere 'weird'.
I hooked the car up on Star Diag last night and I was amazed, the inlet temp doesn’t exceed 70C (full load) it used to slightly exceed 100C. I don’t feel the difference but I can see it on starDiag. I think it works great on back to back runs on a track or a drag strip, the blower doesn’t disengage like it used to. That’s all I can tell you for now.
Peace
Old 12-04-2006, 09:41 AM
blackbenzz's Avatar
haters crazy
Originally Posted by E.fifty.5
just too busy...
Peace
Where did you get the heat exchanger and what are the dimensions?
Old 12-04-2006, 10:08 AM
  #32
stevebez's Avatar
Dimensions and fluid capacity would be very usefull ... also some idea of how simple the install is would be usefull too ... i.e. did you need to cut away at bumper / mountings at all ... ?
Thanks in advance !!!
Old 01-24-2007, 06:35 AM
  #33
stevebez's Avatar
Come on dude where is the Love?
Old 01-26-2007, 03:27 AM
  #34
mstenberg's Avatar
2004 E55
for me
and
for Stevebez
I/C dimensions pretty please
Old 06-10-2007, 08:46 PM
  #35
Jrocket's Avatar
E55
Any more info or dimensions available yet?
Old 06-11-2007, 06:17 AM
  #36
amalamud's Avatar
CLS55 06 (K4, LSD), Range Rover Sport 06, Bentley Flying Spur 07
Sorry for the dumb question,,but by the heat exchanger,,do you mean the radiator??
Old 06-11-2007, 06:42 AM
  #37
Zod
Zod's Avatar
CLS55 2006, CLS 63S 2015
just too busy...
Peace
I am to scared to let people other then the dealer touch the car... but guessing in dubi its not that big of a problem temptation to visit keeps going up and up
Quick Reply: Larger IC heat exchanger!!
