Any pics of Jangys elm set up???
I'll post some tonight. It is mounted facing down up under the passenger leg area. It has knobs extended through the box so it can be adjusted on the fly.
It still raises the same abount that it did, just not to the same point that it did. If the car is lowered by ELM and I hit raise it simply saises up 2" or so. It does not raise to 2" above stock height.
Tighter with more grip (more negative camber). Definitely not bouncier. The beauty is that you can have a low ride and keep it in comfort mode so you don't get the teeth shatter ride. You can also go all out and go low and SII when the roads are fairly smooth. It really is a great tuning piece when used along with the OEM buttons.
Thanks bro. Again, i didn't do the install. I just had the idea and asked about it. I was hoping it was step 1 in getting a relationship going but you know how it is when you wake up and she just isn't quite as cute as the night before!!
The cost is about $1200 (introductory price) installed, depending on where and who you get it from.
