E63 Paddles mod
Old Jan 9, 2007 | 10:17 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
E63 Paddles mod
So I was able to get my hands on a set of E63 paddles. THanks to my service tech he was able to order me a set.... I am going to try to retrofit these into the E55 steering wheel.. THe paddles are bigger than the buttons so the steering wheel needs some retro fitting.... Anyways wish me luck!
Old Jan 9, 2007 | 11:23 PM
deaguero's Avatar
2009 C63 Black on Black
Talking Take lot's of pictures!
Good luck x-tian-230k! take lots of pictures and send the final shot too!
What did the paddles themselves cost?
Old Jan 9, 2007 | 11:45 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
dude you want some help?
Old Jan 10, 2007 | 12:34 AM
Yeah I will be sure to take alot of pictures... As for the cost of the paddles, I paid a little over a hundred for them. I forget the exact amount as I ordered them 3 weeks ago. They were on back order...
Old Jan 10, 2007 | 12:36 AM
Pete,
I will take all the help I can get. I am going to try to attempt this tommorow. Do you know what types of screws are used to attach the air bag? Are they hex screws or regular philips?
Old Jan 10, 2007 | 03:45 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Please let us know the part numbers - I want to give this a bash too...
Allen key for steering wheel itself think 10mm - quite deep tho, and torx for the air bag - not sure of the size sorry, but also very narrow access and deeply set so need a long bit - extensions I found were too fat...
Advice is keep key out of ignition / completely off (and keep it off) when you re-re the airbag ... otherwise you will thro an airbag light that needs a dealer reset.
Old Jan 10, 2007 | 05:23 AM
phatmitzu's Avatar
2005 E55
Mad props! Good luck dude.
Old Jan 10, 2007 | 06:53 AM
BlackCard's Avatar
CLS55 AMG
Can you go ahead and post the Part Number. If this works, you know EVERYONE is going to want it, including myself. I hate the buttons.
Old Jan 10, 2007 | 09:47 AM
Up until this point, I have not heard of anyone trying to retro fit these onto an E55. If this is possible, I would be the only one. I am not sure I would like to have EVERYONE have this mod.... heheh j/p-ing. I posted the P/N on another thread. It was a verification thread. But here it is again....
171-267-00-46
I wouldn't go buy these right away as I was warned by my tech that it might be a different resistance as the button shifters and it might need some modification i.e adding resistors or taking out resistors.
Old Jan 10, 2007 | 11:12 AM
BenzoBoi's Avatar
Super Moderator
W221
Best of luck on the project...
If it does happen, I will definitely be all over this!!!
Old Jan 10, 2007 | 11:27 AM
the yellow man's Avatar
06 Merc E55, 996TT
Cant you just retro-fit the whole wheel? I like the 63 wheel alot better...
Old Jan 10, 2007 | 11:47 AM
Not sure if you can retrofit the whole wheel but if you can it will cost you BIG $$$. New airbag and steering wheel. 100+ dollars and a little bit of modification or spending 1500+ on a new steering wheel and airbag... Let me think about that one....
Old Jan 10, 2007 | 11:50 AM
BiTurboAmg's Avatar
SL65 AMG
Get those bad boys installed then help me get a set for the sl. I have been wanting those and found the entire wheel on this forum from amg that had suede and the paddles but never could find any more info on it. Good luck buddy!
Old Jan 10, 2007 | 11:58 AM
Thanks Jude... I will try to get it done by tonight...with pictures... I just gotta make sure i have the right tools to remove the steering wheel.
Old Jan 10, 2007 | 12:10 PM
55fanatic's Avatar
anybody think I could retrofit paddles to a car with no paddles?
Im around this weekend if you need some help
Old Jan 10, 2007 | 01:06 PM
Kev04C320's Avatar
'09 911 C4S
It should be possible coz Kleemann has been doing it as part of their 50K upgrade as well.
Old Jan 10, 2007 | 01:08 PM
Peter,
I think your a control module away from that mod....
Old Jan 10, 2007 | 01:26 PM
BlackCard's Avatar
CLS55 AMG
I don't think you need to remove the wheel. Just disconnect the battery (so you don't blow your bag) and remove the 2 hex bolts behind the wheel. The bag should come out and you should have direct access to the buttons.
Do a search on Kevin M., when he bought his car last year, he changed the wheel and had pics with the airbag out. It may be on the other benz website.
Good Luck
Old Jan 10, 2007 | 01:37 PM
Good Luck
Thanks for the info. I might have to remove the wheel because i might need to do some modification on the button housing as the paddles' housing is a bit bigger. So a dremmel might be involved.... eeeek...
Old Jan 10, 2007 | 02:20 PM
phatmitzu's Avatar
2005 E55
...171-267-00-46....
How much did it set you back? If you dont mind me asking.
Old Jan 10, 2007 | 03:08 PM
Ball park 130.00-ish... i forget but it was around that much. These are really nice and heavy. Full metal. I have M3 SMG paddles and they are plastic and cheap.
Old Jan 10, 2007 | 03:41 PM
55fanatic's Avatar
DREMMEL BAD!!! DREMMEL BAD
aye man, its two allen keys to take the wheel off from behind, disconnect airbag, torx bit to take off airbag
then I bet its a screw from the inside of the steering wheel to get the buttons off. then use a file... to gently increase some space for the new buttons to fit...
Old Jan 10, 2007 | 03:42 PM
55fanatic's Avatar
Peter,
a control module huh? more info please? I bet I would also need a custom made stone steering wheel with cut outs for paddles?
Old Jan 10, 2007 | 03:53 PM
Pete it doesn't need to be custom made. Just buy an AMG steering wheel with paddles....
Old Jan 10, 2007 | 04:12 PM
55fanatic's Avatar
do AMG wheels come in stone interior? I didnt think they did... a white interior with a charcoalsteering wheel is gonna look a bit ugly dont you think
