Oil leaks from higher pressure w/ pullies?
Since this board has the highest base of experience with assorted mods including pullies, has anyone experienced issues with the pulley creating too much boost (w/ or w/o other modifications), causing oil leaks?
I've heard that the valve cover gaskets may blow, and may eventually cause a headgasket leak.
This was experienced by someone after 3k miles and removal of the pulley solved the problem.
Ted
The person who experienced the problem mentioned above has gone on to explain that it was a result of a new pulley on the s/c itself and once removed the problem disappeared. The crank pulley remains in place without issue.
So this amounts to a big, "Never mind."
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Haven't heard of anyone replacing the supercharger pully.. majority of people on the boards have the crank pully placed.. I've had K1 for about 4 months with only 1 issue.. "traction"!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Advice: ignore what he said. Did not make an ounce of sense.
i dont think that guy on 6speed knew all that much at all
JWade
none
A buddy of mine developed engine leaks when he installed a paxton S/C on his mustang. After lowering the boost and applying crankcase vacuum the leaking pretty much stopped. I think that too much boost, bad engine sealing, or too much CC pressure could all possibly result in engine leaks. No?
E 63,E55 (gone) E46 ///M ,B5 stage 3 S4 ,E36 ///M , 03 EVO (800 WHP)
You may want to check your crank chaft seal, when i installed my evo sport pulley they were alittle over tightened which cause a leak from the seal and i had to replace the seal.
