About to pull the trigger on the CCW C14, need final opinions
Old Feb 7, 2007 | 03:59 PM
mamamiakeroppi's Avatar
Guys!
After several e-mails talking to John @ CCW, i finally found a rim that might work with my tire setup for the E63
F: 265/35 ZR18 Potenza RE050A
R: 295/30 ZR18 Potenza Re050A
It is the CCW C14 with anodized black finish
F: 18 x 9
R: 18 x 10
The rim will look similar to this
And here are a few example images on how the anodized black finish will look like
What do you think guys?? Will it look decent on an E63?
I still have to make sure with John that the 265 front and 295 rear will fit with absolutely no rubbing. If these tires doesn't fit, i would rather go the 19 inchers CCW 505A and run the 255, 285 tires instead.
Any comments will be great!
Ian
Old Feb 7, 2007 | 04:18 PM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
Thumbs down
NOT ON A BENZ.
Old Feb 7, 2007 | 04:23 PM
Blue_Monster's Avatar
215
Originally Posted by BMWEATR
NOT ON A BENZ.
X2
Old Feb 7, 2007 | 04:25 PM
Kev04C320's Avatar
'09 911 C4S
The T10 looks better
Old Feb 7, 2007 | 04:38 PM
newton22's Avatar
BMW E39
Not my cup of tea. Watch out, those 295s could rub.
Old Feb 7, 2007 | 05:45 PM
jmf003's Avatar
'03 SL55
Must be me. I liked the wheels, although silver better than black.
Good luck with the decision!
Old Feb 7, 2007 | 06:01 PM
allied107's Avatar
07 CLS550 & 05 E55
No defentily not on a benz. Keep looking if you need help I can help you.
Old Feb 7, 2007 | 06:03 PM
2K6E55's Avatar
AMGs
Originally Posted by Blue_Monster
X2
+3. Dont DO IT!
Old Feb 7, 2007 | 06:06 PM
baldmike73's Avatar
not a benz. if you are looking for that style look at the BBS CH instead.
Old Feb 7, 2007 | 06:26 PM
SteveFox's Avatar
Bentley Flying Spur, CL550
Originally Posted by 2K6E55
+3. Dont DO IT!
Old Feb 7, 2007 | 06:39 PM
jangy's Avatar
2015 S212
Looks are up to you. I like CCW's attitude, so do it if you like. Why are you saying to get a 19 with the 505s? Why not 18s either way?
Old Feb 7, 2007 | 06:54 PM
Haha, thanks for the honest comments guys. I knew you will not like it... the thing is, CCW wheels are a lot more affordable than their competitors, and they're light!
I actually like the 505A more than the C14. For the 18 inchers however, they say the C14 will clear the stock brake, but the 505A will not, due to the curvature of the spokes.
So i decided to sacrifice look for performance. jangy who decided to stay with the 18 inchers could run 275 front and 295 rear with no rub. See this thread: https://mbworld.org/forums/showthrea...&highlight=295
running 295s and no rubbing might be possible with the 18" since the diameter of the wheel actually decreases to about 24.9" from the stock 25.3". Then if u go up to the 19 inchers your wheel diameter will go up to 26"!! That's 0.7" increase over stock so it makes sense that it rubs.
Staying with the 18" also allows me to use tires such as the RE050A Pole Position, and the Yokohama Advan Noeva AD07.
So for max performance, staying with the 18" seems pretty good. But of course the aesthetic of C14 doesn't quite work with Mercedes Benz. Is there any other 18" wheel out there that cost around $2600 and has the same look as the CCW 505A?? 505A has a 5 spoke design.
Ian
Old Feb 7, 2007 | 06:56 PM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
Originally Posted by mamamiakeroppi
Guys!
F: 18 x 9
R: 18 x 10
Ian
Your sample wheel has 5 lug holes and 5 dummy holes in the hub of the wheel. All cars shown have only the 5 lug holes, which is better.
