Evo Sport Headers
I was quoted $5200 for the headers plus install. Does this seem a fair price?
And, i was also quoted a gain of 30-40 hp
I am new here, dont want to make a wrong decision.
Thank u in advance.
-K
http://www.evosport.com/product/prod...VO.EXH.M11.H03
Thank u in advance.
-K
I was quoted WAAAY less than that for the RennTech one, that I prefer.
Not to steal this thread, but who else makes a shorty (bolt on) for our cars?
And one more thing... are they worth it?
Thanks alot guys.
-K
). I'm looking for headers myself, and I'm torn between the RennTech and EVO ones. Each seems to have an advantage. If you aren't in a major rush, you may want to wait a bit for one coming out that will have the best of both and then some!!
Evosport headers retail for $2995 and we can ship to Dubai.
Our evosport headers are shorty headers that will give good power gains. Along with software and plugs you will see 35 to 40hp without having to modify your catalytic converters, and affect your emissions.
The coating we use on our header not only helps with exhaust scavenging, but also reduces underhood temps which is always a problem on force induction cars.
Evosport headers also can match the quality and power gains of any shorty header on the market for less money.
Dale from evosport
Dale from evosport
Dale
They are different in materials (Renntech uses SS while EVO uses aluminized steel), design (RennTech is 4-2-1 and EVO is 4-1), and coatings (Renntech is not coated and EVO is ceramic coated) for starters. All a matter of preference, really. Each has its advantages and both claim to give the "best" gains.
Someone correct me if I'm wrong. A 4-2-1 design is typically for mid range power and torque where a 4-1 design is for upper end power. A 4-1 design usually produces a slight more power than the 4-2-1 design. Anyhow, I do like that EVO is ceramic coated.
While I do like the coating added to the EVO ones, the Stainless Steel of the RennTech ones is a nicer raw material. I typically have all of my exhaust components coated anyway prior to instll, so it all comes down to your preferences.
Personally, I am still searching for someone to release a new one that has the best of all.
Being the designer of Evosport headers, I am biased.
Evosport headers are shorty design, intended to replace stock factory manifolds without any cutting or modification to the factory catalytic converters. The reason for mild steel vs stainless has to do with stainless propensity to crack after a number of heat/cold cycles. Mild steel is more flexible and when coated offers the corrosion and heat containment benefits of stainless along with lower cost.
Also evosport headers are true 4-1, vs. Renntech 2-1, 3-1 design.
Many customers have seen 25-30RWHP gains, including Vrus.
http://performanceweldingheaders.com/svsm.htm
Evo most likely coats their headers so they don't rust / corrode out in a short period of time. Stainless doesn't require coating since they aren't subject to rusting out. Not everyone is convinced at the effectiveness of coatings in reducing underhood temps, but most will agree that they enhance appearance and help prevent corrosion. There was a previous thread about the relative merits of the Evo versus Renntech headers. Either would be an improvement over the stock exhaust manifolds; too bad Evo does not offer a version of their design in stainless - which would seemingly be the best of both worlds. They could even use a grade of stainless that OEMs use, which wouldn't be, as Evo claims, prone to cracking. And they could go all out and use single piece mandrel bent primaries, instead of the butt welded segments their design currently employs. Heck, if they offer a set like that, I'd buy.
If cost is an issue, get the Evo's. If cost isn't an issue, get the ones you like the looks of better. Performance gains will be about the same with either.
For the money I think its a good performing header.
