PIAA City light guys! Ineed a favor, noticing a problem here!!!
Got a quick question. I ordered the piaa extreme white bulbs for the city lights, ( the small little blue wedge bulb) its the same one all you have got installed(from the threads)
I love the bulb, they look amazing, wouldnt want to go back to stock, however, last night i had the lights on and i was pulling up to a wall, (never done that before) and i noticed that the city lights were very slightly dimming or kinda flickering kinda often. They werent shutting off and turning back on, however it was a kinda slight slight dimming every few secs.
Its wierd, if the engine is OFF its fine, but with the engine running it does it. I have never noticed it before. Its probably only visable at night....
I was at lucent motors when it happend, and the head mechanic said that its wiered to the interior lights and when the engine is running, its probaly using a little to much volts and causing it.
If the engine is started, the drivers door open, radio on, and you will see the city lights flickering....
Will somone with these bulbs please check it out and let me know if i am the only one with this problem?
Once again, its got to be very dark (closed garage, or at night) to notice, ive had these bulbs for 4 months and this is the first time i realized.
-Thanks,
Jordan
-Thanks,
Jordan
You said flickering in your original post thus my response but I just checked mine, no issues.
Do you have a large sound system with multiple amps? The amps could be pulling power??
-Thanks,
Jordan
If the Engine is running, not only are the city lights dimming, but if i open the cars doors and look inside of the car with the engine running, all the interior lamps are flickering. However, if i put the headlight selector switch at 0, when all the headlights and city lights fog lights ect are off, the dimming stil occurs with the engine running.
If the engine is off, there arent any problems once so ever. What do u think.
