K2 Wagon Dyno
K2 Wagon Dyno
I had the car dynoed yesterday - after I installed the bigger Johnson IC pump. As you can see the bigger pump did take the heat soak better or the engine did not loss as much horsepower.
The wagon has the K2, VRUS' 80 mm TB, House of Power CF Box with the ITG air filter and Johnson IC pump. Next up, lighter wheels.
My numbers are right in line with yours with the same mods. I'll be going back on the dyno next week once the airbox is fitted. I'll be sure to post the results along with pics of my most recent additions.
It looks as though that pump was well worth it...
Sorry, no pics of wagon - but as soon as I get the camerca back from the wife, I download the pics of the Johnson IC pump kit that I got from Cory at Kleeman and the stock pump. There is a BIG difference between the two pumps.
V12-Biturbo
Great final #'s a true beast! but your torque curve isn't very flat drops extremely quick towards red-line compared to others I've seen, also rwto doesnt peak until 3700rpm's? should be peaking @ 2000-2500rpm's
W210, W220, W163, W164, C6
Very nice results!!! Did Gil say what the SAE corrected numbers were?? My buddies, yellow TT C6 and TT GTO are at the shop...fine work from NRP!
