Totally bummed with new HRE’s
Old 04-16-2007, 10:30 PM
Super Moderator
BenzoBoi's Avatar
W221
Go back to where you got em and give'em hell!!!
Old 04-17-2007, 02:03 AM
Former Vendor of MBWorld
BlackC230Coupe's Avatar
Fast Cars!
So? where did u buy them from?
Old 04-17-2007, 02:08 AM
03c4s's Avatar
07 E63,03 c4s,01 tahoe, 00 RL
Originally Posted by gE63
I bought them through a retailer. I don't know who is at fault. I don't want to bash anyone either. I just want them fixed. The rears rubbed bad enough that I had to take them off yesterday. Right now I'm riding around on OEM rears with HRE fronts. I'm sure you can imagine how nice that looks.
G.
Nice look, make sure nobody takes a picture..
Hope all goes well,call me if you need help in getting things resolved.
R.
Old 04-17-2007, 02:10 AM
rlee02135's Avatar
2004 C32 ///AMG
Do you know which numbers in the serial number represents the offset?
should be a 12-digit number
My front wheel is R8A19P306515
stands for:
R8A19P306515 8-series wheel
R8A19P306515 19" wheel
R8A19P306515 Offset: ET30
R8A19P306515 6.5" Inner Barrel
R8A19P306515 1.5" Outer Barrel/Lip
Old 04-17-2007, 09:27 AM
gE63's Avatar
E63
stands for:
Thank you for the explanation.
Based on the above my offset is:
ET 33
6.5" Inner Barrel
3.5" Outer Barrel
Old 04-17-2007, 09:30 AM
Out Of Control!
JamE55's Avatar
Where did you buy them from?
Old 04-17-2007, 03:08 PM
  #32
Fast Cars!
Let others know were to stay away from!
Old 04-17-2007, 03:21 PM
  #33
jangy's Avatar
2015 S212
Originally Posted by jangy
That makes 2 sets of HREs that were just released with the wrong rear offset (too agressive in both cases). Just for the record, they were from 2 different vendors.
IMO the rears should be closer to et42 for a 10" width.
This isn't an isolated thing. It is an HRE thing. Also, neither client is complaining about not getting them fixed. their complaint is in not having it done the first time. For once, I'm glad I didn't get my rims!
Old 04-17-2007, 03:37 PM
  #34
crhait's Avatar
see sig
I had the same issue with my Carlsson's. Fortunately, I was able to shave 2mm off the supplied spacers
Old 04-17-2007, 06:28 PM
  #35
Jrocket's Avatar
E55
ET 33
6.5" Inner Barrel
3.5" Outer Barrel
Tire sizing issue maybe?
Old 04-17-2007, 06:31 PM
  #36
jangy's Avatar
2015 S212
I agree on tire size, but i also think that running 275s max is restrictive. et33 is pretty aggressive in the rear with that much width. For reference, the SL550 rims are 18X9.5 et33 and they rub with anything larger than 275s.
Old 04-17-2007, 07:10 PM
  #37
Jrocket's Avatar
E55
Ali's are 31offset with 285-25' on his R10 20's.Jays are 35offset.So maybe its different to each manufactures way of measuring?
Old 04-17-2007, 07:49 PM
  #38
jangy's Avatar
2015 S212
That is odd. I'm pretty sure jay runs 285s and has plenty of room on the outside. It may be time to take a ruler to the rims? Oddly, enough, Jay's are HREs as well and they have done enough W211s to know by now.
Old 04-17-2007, 07:55 PM
  #39
John@CarLabMS's Avatar
one issue that people aren't really thinking about is tire manufacturer.
example:
fk452 285 is about equal in width to a bridgestone potenza 275 or sometimes even a 265.
falken, happens to make their tires very skinny. bridgestone, on the other hand, happens to make theirs very wide.
michelin is a little on the wide side, as is federal, but federals are taped in a more linear fashion from tread block to bead, than michelins are, so federals usually will not rub with the same size/offset when michelins do, purely because of the sidewall shape, and not how wide it is.
it could be that the 285's one person is running is a plus sized 285 vs a skinny sized 285.
another example, i had a 265/30 19 michelin ps2 next to a 285/30 18 toyo t1-r, and they were actually the same exact size (section width).
some food for thought, that is probably why some people are having a problem, and others arent.
Old 04-17-2007, 08:02 PM
  #40
gE63's Avatar
E63
It looks like I have three options.
1) Roll the fenders. (Not going to happen)
2) HRE can shave 3mm. This would give me et36. I'm not sure this is enough. Does anyone know how I can measure?
3) HRE can replace the barrels. 3" outside, 7" inside.
Number 2 is the quickest option. What do you guys think?
Old 04-17-2007, 08:19 PM
  #41
jangy's Avatar
2015 S212
I think option 3 is it. I don't know that HRE would shave them and keep your warranty. I say let HRE switch out the barrels. They have the right offsets and the customer service, so it is only your time. Don't make a hasty decision and then wish you had waited.
  #42
Jrocket's Avatar
E55
example:
So the Toyo's measure skinny also?How do the Contis compare to the Kumo's and Toyo's on section width?
Old 04-17-2007, 08:22 PM
  #43
Jrocket's Avatar
E55
Jays wheels are 34 front and 35 rears,oddly enough I got that info from HRE directly.
Ali's car has 34 fronts and 31 rears,but Im not sure if fender rolling will be needed.Also not sure what tirs he has but Im betting Kumo's or Toyo's.
Old 04-17-2007, 08:23 PM
  #44
Jrocket's Avatar
E55
They will chane the centers out if anything for you.I would think you only need another 2mm but then again your running a tall tire too?
Old 04-17-2007, 09:02 PM
  #45
sdsilverm3's Avatar
Ali has Toyo T1R's. The Toyo's are recommend for people who dump their cars based on the reduced width and angled shoulders.
Greg, option #3 is the best option. Everything else is a band-aid fix.
Old 04-17-2007, 09:07 PM
  #46
Administrator
Rock's Avatar
Drives Slowly
Interesting read, a lot of factors at play here.
Tomorrow, I am having new PS2's installed on my BBS LMs. Front and rear wheels have a 32+ offset. Sizes will be 255/35/19s for my 8 1/2, fronts and 285/30/19 on my 9 1/2 rears.
My MB master mechanic thinks............................. it will work!!!
Jangy states............................................ ..it might work???????
Rafal warns............................................. .....it wil rub!!!!
I look at it this way............. the worst case scenario is that someone from MB World gets a hell of a deal on new PS2s. Now, is that all bad?
Old 04-17-2007, 09:17 PM
  #47
Jrocket's Avatar
E55
Well then...I'll start the bidding with a 20 spot!
Old 04-17-2007, 09:31 PM
  #48
sdsilverm3's Avatar
I'll put my money on RUB.
Old 04-17-2007, 09:42 PM
  #49
rlee02135's Avatar
2004 C32 ///AMG
go for #2. my 9.5" rears are rubbing, so i am having this done w/ HRE too.
replacing the barrel is just too much $$ ($400 each)
i'd just cut the wheel, go down a tire size and roll the fenders.
Old 04-17-2007, 09:44 PM
  #50
gE63's Avatar
E63
Have a look at the attached picture. You can clearly see where the tire was rubbing the finder. From that point to the outside of the tire is almost an inch. So now I'm not sure getting an extra 1/2 of offset will work. With an additional 1/2 inch of offset I believe it would be et45?
Quick Reply: Totally bummed with new HRE’s
